481 - 500 of 577 Posts
Hi,
I have F25 with
-S6NHA Hands-free with USB interface
-S609A Navigation system Professional
Which if I've understood everything correctly should mean I can enable Enhanced Bluetooth?
I've got my self an E-Sys Ethernet cable - so guess I just need the relevant software to get going?
Is it literally as easy as indicated here: http://www.bimmerfest.com/forums/showpost.php?p=8020396&postcount=7
Also, would this enable BMW Apps over Bluetooth?
Hi,
I have F25 with
PM sent.
Yes, it is that simple.
No, you will not get BMW Apps over Bluetooth. You will need to use cable.
Hello @shawnsheridan!
I have a 14 BMW 328i, I have the combox in the trunk and would like to code the Bluetooth audio feature. I ordered the USB to OBD II cable, would that work or will I need an Ethernet to OBD cable?
I'm using a Windows 10 VM on a Mac, I need some help with the software part. Can you please confirm if I need Esys, the launcher and the psdzdata_lite for this tweak?
I'm following https://youtu.be/xbO4yWIFXoA , can you also please advise if I need to take care of anything else?
Thanks in advance
I***8217;m using a Windows 10 VM on a Mac, I need some help with the software part. Can you please confirm if I need Esys, the launcher and the psdzdata_lite for this tweak?
I***8217;m following ..., can you also please advise if I need to take care of anything else?
Thanks in advance
You need an ENET Cable for F-Series car, not a DCAN Cable like you bought. PM sent.
Hi guys. I have some time reading in the forum and it's really great, a lot of useful information and really good coding stories. Now my question, I have a 125d, 2015 said in papers but vin information says 20130901. I want to unlock my a2dp, I read the vin information on bimmerwork and 6va is not listed, so I understand I have nbt unit but I am not sure, do you know other way to check the head unit without unmounting the panel?
By the way I have no navigation, only hands free bt calls through phone and WhatsApp.
Thank you.
Thank you.
No navi = No NBT = No EBT
Launcher Premium is no longer supported by tokenmaster, only PRO for which he is requesting a $50 donation to a charity of your choice. Does anyone have any workaorunds? or previous builds that dont require emailing the tokenmaster for activation codes?
Thank you. What do you recommend to get ebt in my car, retrofit a combo, a nbt, an Android car or any other option?
Thank you.
There is no workaround, only paid alternatives like ESysX, that cost more.
Why not just get the new Launcher Pro 3.x version? :dunno:
For the first 5 years, before Launcher PREMIUM came along, we all paid $50 for a 12 month E-Sys token, year after year, and were happy to do it. Making a donation of $50 every 2.5 years to be able to code one's car is dirt cheap by comparison, and certainly more than reasonable, and the money goes to a good cause to boot. It's Win-Win.
Enhanced Bluetooth 2018 X3
Hope someone can shed some light. Just purchased a 2018 X3 (G01). Didn't realize you need to order the wireless charging for enhanced bluetooth, so i'm missing it. I have nav.
Can I code for enhanced bluetooth on it? I see S609A, but not 6NH or 6NS.
If you have NBT2, add 6NW and VO Code NBT2.
Im trying to code ebt on a 2017 f31 with pro nav, nbt2, idrive 5. I've VO coded both 6ns and 6nw but neither have worked. I now get an office option in settings, but no options to add a second phone bt audio doesn't work.
I've seen a few people with similar issues - does anyone have a solution for this?
TIA
I
Hi guys,
i believe this is also feasible for E series? I have an X1 from 2014 with 6NH and would like to change it to 6NS in order to enable enhanced bluetooth option.
May i have the link for the software please?
thank you in advance
Hi guys,
