Coding F30 335 EKPS
1 reading
12K views 55 replies 16 participants last post by  johannvanrooyen01
#1 ·
Guys,
I'm trying to program a brand new EKP module for F30 335 (13 MY), and was wondering if you could teach me how.
I've watched videos of people using NCS Expert to do so, but it seems like it's only for E chassis vehicles.
I've also seen a couple videos of programming the module with ISTA-P and ICOM, but unfortunately I don't have an ICOM device.
I have ISTA+ that I've downloaded, which seems to be missing data folders in PSdZ folder, and an ENET cable.
Is there a good reading material on how to program this module for F30?
It would be fantastic if you could give me some clues.
Thanks,
#5 ·
Hey bro, could you please lead me through the steps of coding a used ekpm to my car? A friend of mine already tried it, but i keep getting cel with “fuel supply” and the codes are saying something with no or low voltage to ekps. The donor car is a 530d 2010 that has been in a bad accident that possibly cut off the fuel. My car is a 2014 535i and my current ekpm is still working, but im having some problems with fuel cuts (i guess) and thats why i wanted to try another ekpm to see if that is my problem. With my current ekpm i have no codes
#20 ·
E-Sys - Flashing Guide v.1.0.1.pdf:
#24 ·
Ok, you are lucky as your car has no EPS FSC Code. I would install Donor EPS, Inject CAFD and VO Code it.
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on EPS ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on EPS (the ECU itself not the underlying CAFD) => Select CODE.
#31 ·
No idea. If you install EPS in car, and its connected to BUS, it should appear in ECU Tree with Read (ECU).
#32 ·
Hi Shawn,
I bought an ET3 stage 2 EKPM and need help coding it. They have instructions using protools to change the VIN to match the cars VIN however I did not have these options available to me on protool. Current reading of the EKP's VIN is 0000000.
I went onto Esys and Injected the latest CAFD as per your instructions but that has not helped. Would you know how to adjust the VIN value of the EKP using E-sys?
#35 ·
Try writing Long VIN to EKPM:
E-Sys => Expert Mode => FSC Extended
Use Diag Address 0x11
Press Identify and EKPM should Populate in Base Variant field
Select WriteDataByIdentifierVIN
Select >> to move WriteDataByIdentifierVIN to right side
Enter xxxxxCARxVINxxxxx in Pop-up Field
Select Start button and check Log window for ok result.
Hi shawn
I have attempted to put 0x11 into the diag address and i received an error saying Base Variant not determinable. [G175]
#36 ·
Hi shawn
When you Read (ECU), does EKPM appear in ECU Tree?
#49 ·
Sorry I should have elaborate more, I know you outlined the steps above on how to code the module but is there a more detailed step by step guide?
More detailed then this?
No, not posisble.
#53 ·
Understand that for a non factory fitted ECU, its I-Step Shipment is most likely not the same as the car's I-Step Shipment. The correct I-Step Shipment is one where the ECU being flashed has HWEL in svt_soll that is Black, not Red / Blue.
So after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it.
  • Like
Reactions: guganiel
#56 ·
Hi, I updated my ekpm3 to an ARC Terminator. I’m wondering whether I have to change the individual parameters to allow for more amperage/disable safeties or just update the module to code the new ekp module. I see the ekpm2 dme (which includes ekpm3 in the description afaik). Thank you in advance.
Hi, can I please please get some help. Also new at coding and have esys installed and can connect to car but no idea to code my ARC Terminator EKPM. Is anyone will to remote connect and do it for me? This will be so mich appreciated
