Status
Not open for further replies.
Coding Library All PDFs on Instructions/ToDo's etc:-
2 reading
290K views 370 replies 136 participants last post by  shawnsheridan
#1 · (Edited)
Consolidating all the PDFs
#50 ·
The build date of the car is irrelevant. What matters only is that the PSdZData version being used is >= to the last version of ISTA/P used to program the car. If you use the latest PSdZData, then you on't have to worry about it. Otherwise, you will need to read I-Step current from VCM, cross-reference it to the ISTA/P version, and determine if your PSdZData version is >= to it. 53.0 is pretty new. I would try it and see if you can read all your modules.
PM sent.
Save
#51 ·
Coding Info for F26 (X4)
Haven't seen anything yet on the F26 X4. I just took delivery of an X4 M Sport version and want to make a few mods. I understand the generic platform mods, but was wondering if there are updated files for this 2015 platform and if anyone has a coding sheet yet for the F26.
Thanks in advance !
Paul
Current garage
2015 X4 M Sport - Graphite / Black
2003 X5 4.6is - Black Metallic / Black
2002 M3 Cab - Black / Cinnamon
Former BMWs
2000 323 CiC ESS supercharger (shown at Bimmerfest Santa Barbara 2002)
2000 740i Sport
Save
#52 ·
Thanks in advance !
PSdZData covers all Fxx, including F26. F26 uses F25 PSdZData Target, which means most likely the F25 Cheatsheet is the best match for it.
https://docs.google.com/spreadsheet/ccc?key=0AmtiPUeimOhHdHRjWkhUOU5Lalh0RVRkcTNFTE9MS3c#gid=0
Save
#54 ·
It isn't so much model specific as it is ECU and factory option hardware specific. For F32 though, just use F30 cheat sheat.
Save FA and SVT. To restore any ECU, you simply have to VO Code it with factory FA activated.
Save
#56 ·
Are you getting a [C012] Missing CAFD error?
Save
#58 ·
You need to update your PSdZData, and in turn possibly your E-Sys.
PM sent.
Save
#62 ·
FDL Code ICM = IcmKod_B_InitEco = verbaut.
Save
#63 ·
Need help with coding my F82 M4 (Dallas, TX). I have an OBD cable plus ESYS v3.24.3 and PSdZData Lite v.53.4 installed on my laptop, but no token.
Still trying to figure out what all the coding options are, but at the minimum, I would like to have following features coded:
- Re-code for Dazzle Headlights (LED)
- Enable Variable Light Distribution (VLD)
- Turn on Brake Force Flashing with Hard Braking
- Enable Illumination of Exterior Door Handle LEDs when in Reverse
- Remove Legal Disclaimers
- Add Weatherband Radio to sources
- Close windows, sunroof & mirror fold from key fob
I read somewhere that you do not need a token to code certain features. Does anyone know if any of the above features require a token to code?
My M4 Build:
- BSM / SS Full Leather
- DCT
- 19" Wheels
- M Adaptive Suspension
- Executive Package
- LED Lighting Package
- H/K Premium Sound
- Enhanced Bluetooth / Smartphone
Save
#64 ·
The 1st 2 can be VO Coded, but the rest are all FDL Coded. You need a Token solution.
Save
#66 ·
I don't have have ASS or ECO Pro in my F10, but I am pretty sure ASS On is an integral part of ECO Pro functionality, and I do not know how to disable it if it turns on automatically in ECO Pro.
Save
#68 ·
Hi, I have updated my friend's F01 2011 with the "power and torque" and it shows up but nothing happens when he drives. Also, how can I update it with the M logo? And if any cheat sheets are available I would like to have it, in order to program my friends car with goodies. Thnx in advance
#69 ·
Save
#71 ·
For F01 with CIC, neither actually.
Save
#73 ·
For the Logos, you can't do either. Kombi Logo is for F20/F30 6WA Clusters but not 6WA F1x Clusters, and Head Unit Logo is only for new NBT Head Units, not CIC.
Save
#84 ·
Both issues are known issues and much discussed on this forum. TPMS and Sport Displays do not work in all cars, particularly those with older firmware, and additionally Sport Displays do not work with all motors, such as the case of N63B44 Motor in .50i cars, although it will work with newer N63B44TU motor.
Save
Status
You have insufficient privileges to reply here.
