2141 - 2160 of 2361 Posts
Hi. First time user of E-Sys (v3.27.1) and found that my 2015 650iGC has current I-Step F010-16-11-503. Outside of a couple HU updates i did earlier, SVT actuals and targets match. Don't understand how to select latest I-Step that will work from F10 data in v.4.24.21_PSdZData_Full. Got this far without Loader Pro, waiting on reply to receive DL. Thank you.
Premium Member
Hello Shawn,
I used E-Sys 3.27 and 3.30 wih launcher Pro v2.8.1 + token generator with several PSdZData (v63.3, from ISTA 4.13.14, 4.23.12) but I have a lot of issues during coding like: SVT can not be read (c064), NCD read from ECU failed (c069) cdDeploy FinishedWithError, CAFD not found (c012)...etc.
Can you send me links to the latest E-sys, Launcher and PSdZdata lite and full that work for you.
Thank you in advance for your help.
PM sent.
Premium Member
I don't really understand what you ask. You don't understand what Connection Target I-Step to use?
I had a 320i Sport G20 with analog cluster. is it possible to display the digital speed on this display by coding? Or change the hours or temperature for the Speed?
Premium Member
Not sure what is possible. I have yet to code a G20 Kombi.
Premium Member
That’s correct. There are a couple listed in the f10 datasets.
Choose the bottom (newer) one, without the _DIRECT suffix.
Premium Member
Hello Shawn,
I curently use E-Sys 3.30.1 with launcher Pro v2.8.1.155 + PSdZData v63.3 (5.04.02). I'm really not sure that it's the last version ...
Is it possible to share with me links to the latest E-sys, Launcher and PSdZdata lite and full that work for you.
Thank you in advance for your help. That's really great.
Catolard
Premium Member
Hello Shawn,
Catolard
PM sent.
Premium Member
any word on how to get a new key for launcher pro? i emailed tokenmaster back in may but never heard anything. i thought i was being proactive by giving myself a 4 month buffer.
Premium Member
Premium Member
i had a working installation of launcher pro 3, should i abandon hope?
Use 2.8 PRO for now, and keep trying to get 3.7 PRO from TM. He comes and goes like the wind. Timing is everything.
