Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#608 ·
Hi.
When i try to open my Esys launcher im trying to log in using my e-mail and authenticator generated pin from the app, and then upon trying to log in, esys launcher pro stops responding and closes.
What do i do here? Anybody experienced this? I do have wifi the moment im logging in..
i done every step, install visual component, net framework and java, but it cant working, cant open launcher. how can , fix solve.
#610 · (Edited)
Hi all
I have an f10 2012 and after a 6wa kombi retrofit I an error on istaD is same error as the one attached . I tried to do the I level update with istaP but I get a message to replace kombi any one have any idea what can be wrong? Any help would be highly appreciated I forgot to mention the kombi was virginized
#619 ·
Latest Launcher PREMIUM 2.8.2 version does not support VM use. If you use Mac, you must use Bootcamp.
#620 ·
Not sure. You need to run with Admin rights, and make sure the Windows has latest Java, Microsoft Visual C++ Runtime components, .NET Framework 3.5 and .NET Framework 4.5.2.
And you cannot run on machine with Date Manipulated.
#625 ·
How i can get the Accesscode fpr the Launcher PRO ???
Thanks a lot!
Only way is from Developer TokenMaster (fxxtokenmaster@gmail.com).
#638 ·
Didn't want to start a new thread so I'll put this here...
As far as I know I've followed all the instructions to install Esys. I still get the VIN grayed-out when I launch Esys. I've uninstalled and installed the program a couple/3 times with the same results. I've even used 2 different cables.
#639 ·
  • Make sure motor is running if car is not connected to External Charger.
  • Disable Third party Security Suites (ie Antivirus / Firewall / etc)
  • LAN Adapter is set for DHCP and not using a Static IP.
  • The Target Connection Window should not be blank (See multiple target connections for different chassis)
This post has been deleted
#657 ·
#658 ·
#661 ·
I was looking at Carly's website today and ran across something they claim they can code on G01s: "Maximum volume for the audible confirmation chirp. (codable in FZD)". I'd love to reduce the volume level of the alarm chrip -- it's too loud for me.
Noting that they say it's codeable on G01s in FZD, I instantly looked at @almaretto 's super-helpful CAFD cheat sheet (https://www.bimmerfest.com/forums/showpost.php?p=9756675&postcount=59) which says that FZD2 is either CAFD 00001D92 or 1D93.
Problem is, I don't seem to have that CAFD in my MY19 M40i. But I have the alarm.
And there's another thing that confuses me about Launcher Pro 3.0, stripped psdzdata and cheat sheets. I do have lots of ECUs that appear as "." in the ESys FDL editor. For these, of course, there are no cheat codes shown in Esys. And one has no idea what they really are.
All this has me reluctant to trust ESys and the integrated cheat sheets. For example, consider this screenshot. I'd love to experiment with ASD but first, how can I be sure that F9B really _is_ ASD and what's happening with those cheat codes?
I'd appreciate any clues. But despite all the work people have done to put back what BMW stripped out it feels like BMW succeeded in making coding less reliable than it was in the "early days", circa 2012's F30s. ;-)
#673 ·
Say, has anyone tried coding to "aktiv" ASD_CONFIGURATION and/or ASD_SOUND_OFF in HU_NBT_EVO, 3009 EFFICIENT_DYNAMICS?
The comments read, respectively, (based on my poor German) "Switches the settings menu for ASD on or off" and "Activate a selection in the settings menu to deactivate ASD".
I plan to experiment with these but if anyone knows that they work or don't or you need something else, I'd appreciate any info you might have.
I like ASD. But sometimes its "drone-y". It'd sure be nice to be able to turn it on and off in iDrive.
Thanks in advance.
