Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  spadae2
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#755 ·
Hello. Need help.
I can not code. You are experiencing the following errors.
1) When trying to save the FA it generates this error, access is denied.
2) When trying to click on Reading coding data in the module. It presents this error of "NCD"
I already looked. Esys is set to C: / data. It's all in the right places.
Firewall disabled.
At launcher F30 is selected to 320.
On the F020 connection is not direct.
I tried to open Esys without the launcher. And to save FA the same error appears.
#756 ·
Hello. Need help.
I already looked. Esys is set to ***x1f604; / data. It's all in the right places.
Firewall disabled.
That has to do with user permission to save files. That is not esys config issue.
#765 ·
There is no error. You are checking Specifically for FSC Code AppID 323, which is CarPlay, and your Head Unit does not have this FSC Code.
#771 ·
Hi guys
Can i get a link to the Launcher Pro
Thanks for help
Requesting Launcher PRO 3.x is useless. It won't work without an Activation Code, same as old E-Sys Launcher 2.x, and the only way to get an Activation Code is to generate one using his WebApp, which requires a Access/Code Login from TokenMaster. Anyone wanting Launcher PRO needs to just email TokenMaster (fxxtokenmaster@gmail.com) and get setup by him. There is nothing anyone else can do for you.
This post has been deleted
#775 ·
Hi all
i am new here and i bought a US version F56 JCW and shipped the car abroad
the radio frequency and the sat nav is not working properly in my area i called my local service
and they said the car need to be reprogrammed to your local area
is it possible to do this through coding and ESYS ?
if YES please send me all i need
thank you
#776 ·
Hi all
thank you
Yes. See Post # 1.
#778 ·
Any $20 ENET cable off eBay or Amazon should work fine.
Software Links are in Post # 1.
#784 ·
Will this work fo the new 2019 X5? I want to program out the annoying dimming of the iDrive display. The dimming is too excessive even on bright sunny days if you drive into a tunnel or shade etc. BimmerCode doesn't seem to work for this.
In general, it works for all Fxx-/Ixx-/Gxx-series Coding; however, considering G05 is all new, and it contains new MGU Head Unit, I would expect some CAFD Mapping issues.
#786 ·
I have some issues withe the latest E-sys und psdzdata files .
Esys : 3.31.0
Psdzdate : v4.14.34_lite
launcher pro: 3.2.1.153
My car : F56_18_11_531_V_004_000_001
When I now connect to my car I see all SG's but with no entries . I think there must be a mapping problem. But I don't now where.
Maybe someone can help me :)
(...) means the PSdZData is Trimmed. If E-Sys Launcher shows Trimmed CAFD (FDL Code) Data, it means either E-Sys has Incorrect Target Connection, or you do not use E-Sys Launcher to open E-Sys, or you use E-Sys Launcher PREMIUM but select wrong car Series or this particular ECU CAFD is not mapped in E-Sys Launcher's CAFD Mapping Database, or you have insufficient Java Memory in order for E-Sys Launcher to map it.
#790 ·
Thank you guys . I try to instal 64bit Java and that try to start e-sys again.
I have forgotten something . I use Windows 10 1809 -> Some people has problems with that . For what I have to pay attention ?
For 1809, you will either have failed error with opening e-sys or not. Since yours is loading, nothing to check.
After you use 64-bit java, make sure to verify it is working by searching "javamem" in E-sys Logs.
#792 · (Edited)
Hello guys
Can somebody help me with this please?
I also noticed that once I selected car from Loader, it said the car can't be charge for some time, if I buy Pro Loader, will this fix this so I can change car faster?
E-Sys: 3.27.1
Launcher Premium: 2.8.x
Many thanks
Set Launcher Memory setting to "Default".
PRO version has no Car Series restrictions.
#795 ·
Hello,
Is it possible with a properly functioning LauncherPRO 3.2 (+ Google Authenticator) to do an SSD upgrade without losing the activation due to a detected hardware change?
Best regards
Unlikely. Make yourself new Key after SSD Upgrade.
#797 ·
Software
Hello,
I'm new to BMW ownership, not new to messing about with cars though ;) so thanks to all of the usefull information you guys are putting out there. I coded out the Start/Stop very quickly and have done some various other bits of coding, all succesfull due to the fantastic enthusiasm shown here. I come form a Saab world which also enjoyed huge enthusiasm.
So, down to business.
Mega download sucks big time and I really need a full psdzdata version to flash a new trailer module.
Can anyone help with i direct download location? @shawnsheridan perhaps?
#798 ·
Hello,
Mega is direct. You can always pay $5 for premium account and download quicker.
#801 ·
Hi, proud new owner of F80 M3 in the UK. Ive bought a cable and installed software as supplied with it. Running E-sys 3.28.1 powered by tokenmaster premium v2.8.2.155. I can connect and read succesfully, setting FA to active but when I right click and 'read coding data' on the FEM module I get an error.
CAFD_00000794_017_068_102 Fehler:
File for cafd_00000794-017_068_102 not found [C012]
I've researched and found similar threads that suggest a 'detect CAF for SWE' should fix the CAFD error except this is greyed out.
Further research seems to suggest the Pzad? file needs updating and I'm now getting really confused.
My E-SYS seems newer than the PZad files so it seems crazy to change them, should I delete E-sys 3.28.1 and install a lower version? The software was all supplied with my cable, or should I change the Pzad files in 3.28.1 to older ones??
Getting confused and dont want to ruin my new car. I appreciate I am brand new here but I have tried to reasearch things before asking and am just getting more and more confused.
Should I just buy Vcar and Bimmerlink app on iphone??
#802 ·
This error means you need updated PSdZData.
Detect CAF for SWE is for when ECU is missing CAFD, not for when it has CAFD that cannot be read. And not that you need it, but your does not work as you have E-Sys 3.28.1, and you should have 3.27.1.
PM sent.
