Wrong thread for ISTA. And this is for an E-Series car?Hi there,
Does anyone have the latest ISTA/P (not ISTA+ or ISTA/D)? Because i have to program/code only one specific ECU and my Coding Section in ISTA+ wont work because i have
changed my HU a while ago...![]()
Oh, sorry... No for a F20, but it should work with ISTA/p or not?Wrong thread for ISTA. And this is for an E-Series car?
No. ISTA/P is ONLY E-Series Programming. All other Programming is ISTA+.Oh, sorry... No for a F20, but it should work with ISTA/p or not?
Sadly the Programming Section in my ISTA+ installation wont open/work properly... But in this Video (No. ISTA/P is ONLY E-Series Programming. All other Programming is ISTA+.
You don't seem to understand. The Video shows Programming an F10 with ISTA/P 3.64.0 (I-Level F010-17-11-520), which is ISTA from November 2017, which is almost 4 years old.Sadly the Programming Section in my ISTA+ installation wont open/work properly... But in this Video ()
he shows how to program/update certain ECUs with ISTA/p on a F10 as well. I would give it a try, so i would be really thankful if you PM me ISTA/p
PM sent.Hi, what an amazing forum!
Could you send esys, psdzdata, laucher and the token generator links please?
best regards!
Hello, id like to get Esys with launcher and psdzdata to code my car, i had them but lost my laptop, thanks.
Can I please get a link to esys+token+launcher ? Thank you
PM's sent.Hi Shawn,
Could you send me the link for E-Sys as well? I need to code out 6UY touchscreen delete on my G20. TIA!
Should work. PM sent.Hi all, I have not done any coding for around 2 years and feel a bit lost. I was wondering if you can confirm if the steps are still correct to code my '21 F40?
I have Esys-x 3.27.1 along side ispi host admin (I believe this signs the application or creates the est token??).. I'm able to launch both apps with no problem and Esys-x launches without any warnings about missing token.
Do you think I can just grab the latest PSDZ data and code as normal? (I have my instructions still for FDL coding). I remember I had to use Esys-x as the files did not map correctly in the other version.
Can anyone confirm? And please send me the latest psdz lite data?
Thanks very much!
PM sent.Hi Shawn,
could you send me esys with launcher and psdz (lite) data. my coding is deleted due to dealer update. My current i level is f056-22-11-550. Thanx
PM sent.Hi, I'm looking for all that's required to update 140i idrive 5 to idrive 6 and activate full screen CarPlay, Could you advise. Much appreciated
