Coding: (No Request) Latest Software Links
904763 Views 4273 Replies 1347 Participants Last post by  330iXFree
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
4221 - 4240 of 4274 Posts
BimmerUtility for latest CAFD Mapping. PM sent.
Hi.
I've downloaded Esys and psdz lite but not sure which launcher to go for. There appears to be one called Bimmer Utility and one called Launcher Pro? Is there any preference or do I need both applications? Grateful for any advice. Thanks.
  • Like
Reactions: benos
Thanks mate, very helpful (y)
Good Morning Shawn!
May I get the link for Esys, Psdz data and BimmerUtility?
Thank you very much up front!!
PM sent.
Good Morning Shawn!
@shawnsheridan Could you send it to me as well? Cheers
Hello,
Can I get the latest links?
PM sent.
Hello,
@shawnsheridan
Please could you send me the latest links
PM sent.
@shawnsheridan
Hey!
Could i get the latest links?
PM sent.
Hey!
Hi, does anyone have esys 3.26.1 they could share. Thanks.
Why this specific version?
I have an old version pszdata full (3.55.0.1000) and have difficulty in my current location to download the latest version. Im new to BMWsso if this is a bad idea please let me know. Thanks
PM sent.
I have an old version pszdata full and have difficulty in my current location to download the latest version.
Could you please send me the link for e-sys? Thank you!
PM sent.
Could I please also get the links? Appreciate your service to the community
PM sent.
