Coding: (No Request) Latest Software Links
2 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,290 ·
HKFM => SCH_FBD = aktiv
HKFM => SCH_TOEHKI = aktiv
HKFM => TASTER_FBD = aktiv
Car needs to sleep for about an hour before coding works.
#1,288 · (Edited)
What version of software for G01?
I have E-Sys 3.26.1 and E-Sys launcher 1.0.7.26 which I used a few years ago to setup an F11.
Have now replaced the car with a G01 but when I try to connect E-Sys does not offer any Gxx targets. Do I need to update to a different version of E-Sys/E-Sys launcher or do I just need a different psdzdata? Which versions are needed to support my X3?
#1,289 ·
S15A psdzdata covers F090/F097/F098/G001/G002/G011/G012/G013/G030/G031/G032/RR11/RR12/RR31
#1,298 ·
It's currently Werte 1F4, which is 500 ms (1/2 Sec).
So I would change it to ***8237;BB8***8236;, which is 3000 ms:
HKFM2 = > HKL_REMOTECONTROLLIFTGATEBUTTON_DELAY_OPEN = Werte ***8237;BB8***8236;.
#1,302 ·
Couldn't do this. By default long pressing the trunk button on the remote takes about 2-3 seconds to open it. Few months back I changed it to make it open immediately once the trunk button was pressed but I found its not convenient coz the trunk opened lots of times while I was sitting and remote in my pocket. I wanted to revert to the original default status where it takes few seconds to open when you press the remote trunk button. I forgot which one I coded to change it back to original status.
#1,305 ·
C012 errors for cafd_00005fa9 files
I have E-Sys 3.28.1 with v.63.3_PSdZData_Lite. I am trying to read config of my G01.
I can read FA and read ECU, but when I try to read config of the CAFDs I get C012 errors for all but one CAFD. Typical error is (VIN obscured):
BDC_BODY2 [40] [NVXXXXX]
readCPS o.k.
CAFD_00005FA9_105_049_016 Fehler:
File for "cafd_00005fa9-105_049_016" not found! [C012]
When I look in C:\Data\psdzdata\swe\cafd I can only see CAFD files that go up to: cafd_00005710.caf.001_000_008
Where can I obtain the higher numbered CAFD files I need? Is there a newer PSdZData file? If so where can I download it?
Thanks in advance for any help with this.
#1,307 ·
readCPS o.k.
PM sent.
#1,308 ·
Files for INPA for. F chasis
Hello does anyone have the files for Inpa f series. I have Inpa but no files for my f1 or f01 chassis. I can research the forum on how to update the files but I can't locate the files. I'm new to the forum so I graciously appreciate your support and I will contribute where I can. Thanks
#1,309 ·
PM sent.
#1,310 ·
Does anyone have the latest document for ISTA-P Version & I-Level Overview? The link in the first page is dead. Thanks!
#1,311 ·
#1,316 ·
#1,319 ·
I have been trying to get in touch via Token Master for the Launcher Pro 3.x License Key for last few weeks. I haven't received any response from, is he still issuing licenses?
I saw the post above and configured Launcher PRO 2.8.2 and esys 3.30.1 but I was trying to code my G05 for Lane Change Assit but I could not find the values and the names are not visible fully.
Attached is a screenshot of the same.
Please can some one help how to get the latest version of Launcher Pro 3.7
#1,321 ·
Also I cannot read the SVT always getting error "Generate SVT_Ist failed. [C105]
No one can help with Launcher PRO 3.x. Only TM can provide as it requires an account setup by him. Unfortunately, he comes and goes like the wind.
If you can't wait, get E-SysX instead.
Info@esysx.com
http://esysx.com/
#1,320 · (Edited)
#1,324 · (Edited)
Hi Shawn!
I've installed Esys 3.27.1 software and E-Sys Launcher PRO V2.8.2 Build 162. I getting below error every time I try to edit any CAF.
"An error occurred while processing the EST file "C:\ESysData\e-sys est\Code Away.est". See details for more information. [C157]"
I have tried many times and checked the validity of .est file and my computer's date is set to automatic; everything seems fine. I do not know where am I going wrong.
Any help is appreciated.
thanks!
#1,325 ·
Launcher PRO provides .est. You should not be using it with old "Code Away.est". Uninstall Launcher, remove .est stetting in E-Sys Settings, and then install this Launcher PRO version:
you can use E-Sys Launcher PRO 2.8.2 for free, at least until April 2020 when it expires:
http://tokenmaster.blogspot.com/2019/05/e-sys-launcher-pro-282.html
#1,327 ·
"New" is a relative term. New since when? Last week? Last year?
There has been no Fxx INPA Updates in a long time. If you want the latest diagnosis capabilities for F-Series, you should use ISTA+, not INPA.
#1,332 ·
Hi Shawn
I got a new i3 and need the latest Data/Software for coding, my i3 has I-Level 19-11-530.
Thanks in advance and greetings from Switzerland :)
PM sent.
#1,333 · (Edited)
Hi Shawn,
I'm using
Launcher PRO V2.8.2.162- BFU_XODE Edition
E-Sys version 3.27.1 (build 44813) - 2015-08-13
PSdZData_Lite v4.20.30
to code a 2016 550i (F10).
All worked great until I took the car to the dealership. They replaced my I-Drive selector and did some reprogramming. Now I cannot connect and E-sys shows a no ZGW available message. Also, the connect via VIN option is disabled.
Can you please offer any suggestions or point me to newer files that might help?
Thanks,
Richard
#1,334 ·
Hi Shawn,
I'm using
Thanks,
Richard
No. Nothing you wrote would explain a sudden connectivity issue. Dealer Programming may require updated PSdZData to read ECU(s), but has no affect on Vehicle Connection. Connection issue boils down to Cable and Windows Networking / Firewall, and car ZGW
