Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,666 ·
Hi Shaw,
I coding a F series and all right. Then change to a G series and get this error, why? I have installed the last pszdata and the car is from 5/2019.
Any solutions?
Enviado desde mi iPhone utilizando Tapatalk
Use Read ECU instead of Read SVT.
#1,670 ·
Hi again Shaw,
Maybe a stupid question, but I have a doubt, I use last pszdata when I start E-sys before connect to my car, is a F20, then the e-sys shows 4 F20 conections, which I need to select:
F020_19_11_538_V_004_005_000
or
F020_20_03_540_V_004_002_000
Please what I need to choose?
In other main series have the same problem, have 2 options... and I don't know which option choose.
I know that NEVER will be select the DIRECT option.
#1,671 ·
Hi again Shaw,
or
The newer (bottom) one.
#1,677 ·
Wrong Thread. As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates not for Coding specifics.
Install ECU, Inject CAFD, and VO Code ECU. If that fails, you will need to Flash it.
#1,680 ·
Hi,
One quick question, I makw coding last day with the car, I have all ecu cads in my computer, I saved it from original car, then now is possible make coding with this files, and after have all this files coded and modified upload all this file to the car and no soend time coding with the carn turned on or with a charger conected in car? Habe any tutorial or guide for make it? Thank a lot.
#1,681 ·
Hi,
Again, Wrong Thread. As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates not for Coding specifics. :dunno:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click ECU CAFD File => Select New FDL => Navigate to C:\ESysData\CAF and select matching .NCD file => Left-Click on Inserted CAFD => Select FDL Code.
#1,686 ·
Hi shawnsheridan - I'd like access to the latest e-sys and psdzdata launcher/tokens as well. Looking to custom code my 2016 740i. Thanks a mill!
PM's sent.
#1,697 ·
Alright, so I'm a newb ... very excited to be here, but not sure I understand what I'm getting myself into. I have a 2016 740i M-Sport (G012) and I'm looking to code some minor things like M-animation on the iDrive screen, Alpina colors (not logo) on the instrument cluster, Angel Eye brightness and on w/ fogs, disable iDrive disclaimer/acceptance, close trunk lid w/ remote, and tire pressure/temperature readouts. I have a basic understanding of coding ... I can't write it, but I can usually read and modify existing code. So far, nothing I've researched about how to do this seems above my head. The problem is that there seem to be lots of tutorials, DIY videos, cheat sheets, etc for many bimmer chassis except mine ... the G012. The last thing I want to do is brick my module. Are there folks out there who have successfully coded a G12 who can share specific experiences on what worked and what didn't? Some basic questions I have ... can you code with the engine running? How much time should I set aside for this project? Is it possible to copy/download my existing code so that I can familiarize myself with it offline before attempting to write anything back to the module? What kind of mistakes can lead to bricking the module?
So far I've downloaded E-Sys and E-Sys Launcher Pro 2.8.1 as well as v.4.23.12_PSdZData_Lite. I'm expecting my ENET/OBD2 cable to be delivered today and the first thing I want to do is create a back-up of my existing code.
I'd love to hear from anyone who has experience specifically with G12s. Thanks in advance!
#1,698 ·
Wrong Thread! As Thread title "Fxx-/Ixx-/Gxx-series Coding: (No Request) Latest Software Links" indicates, its for software requests only, not general coding questions. :(
I can't tell you what is possible in G12, as I never coded one. You can code all ECU with Motor Running, except DME /DDE. You can read all ECU Coding Data from Car, and then edit .NCD files offline, and then reconnect to car and write modified .NCD back to ECU(s). For Gxx car, you will most likely need E-SysX for the newer ECU CAFD Mapping, not Launcher PRO 2..8.1.
#1,708 ·
#1,707 · (Edited)
Hi all,
Im interested in perform a Adaptative Light coding on a 2016 F32 435 ix. I tried to use the E-sys software and i cant. Its necessary to have the Launcher Pro 3.x? How can i get the Launcher Pro 3.x?
Nit possible. Developer Tokenmaster has not been responding for some time now.
How can i get the E-SysX? What else i need?
PM sent.
#1,711 ·
Dear Shawn
By any chance do you have a link for a working E-SYS + Launcher what can be activated?
If yes could you please send me a link?
Using the link from the beginning of the thread I tried ESYS 3.27 and E-SYS launcher 2.8 but no luck as the token is expired and doesn't allow me to extend it or am I doing something wrong?
Thanks in advance,
Gabriel
PM's sent.
#1,710 ·
Dear Shawn
Thanks in advance,
Gabriel
