Coding: (No Request) Latest Software Links
9 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,720 ·
Hi Shawn, can you please send me the latest PSdZData lite? I am trying to code the new Assisted Driving View on iDrive 7 and also unlock Lane Change Assist.
Here is what i have:
2019 330i M Sport with software ver 03/2020.31
E-Sys 3.34
Launcher Pro 3.7
PSdZData lite 4.21.12
I am hoping the latest PSdZData lite will have this file and fix the error:
DKOMBI4 [60]
readCPS o.k.
CAFD_00004508_003_001_051 Fehler:
File for "cafd_00004508-003_001_051" not found! [C012]
#1,726 ·
Hello Shawn , as Token expired, can you send me links For the last E sys + Token+ Launcher Working
Thank you in advance
Hello Shawn ,my Token expired, can you send me links For the last E sys + Token+ Launcher Working Thank you in advance
Hi Shawn,
I used the links in the OP for ESYS and PSdZData, but if there are newer links can you please provide those as well as launcher pro and a token?
Thank you!
PM's sent.
#1,730 ·
Hello,
Would I be able to use ISTA+ via ethernet with only the OBD to ETH adapter?? It works Ediabas, and E-sys.
if it does can you provide me with the download for it??
#1,731 ·
Hello,
For Diagnosis, yes. For Programming, I believe you will need an ICOM. Sorry, I can;t help with ISTA though. This thread is for E-Sys and PSdZData only.
#1,732 ·
I would just wanted in order to see all the error codes.
I thought this was the right place for all programs. I will look in the forums to see where to find it.
Thanks for the response.
#1,736 ·
Hello Shawn,
Could I also ask you to send me the latest links for E-Sys, ESysLauncher and PSdZData?
Thank you so much!
PM's sent.
#1,748 ·
Good Morning Shawn, I have E-Sys, Psdzdata and Insa+, however I do not have launcher and token. Could you please provide them to me??
#1,753 ·
#1,756 ·
Hello everyone,
I'm new there. I appreciate the multitude of information on this site, and responsiveness of the members without prejudice about those who know less. :p
Before bothering you, I spend several hours looking after procedures and sources on how to code some comfort cheats on my 2015 BMW I3 REX.
I read the page 1 of this thread, related links and comments from well-known, serious and almost each time present Shawnsheridan, Almaretto and ... Tokenmaster.
Actually I installed Esys 3.27.1 Plus 2.8, psdzdata 5.01.02 from the link. Honestly I lost a bit of time trying to understand if I need a launcher, which launcher, a token or not token... still unclear to me :dunno:
I tried of course, following procedures, and went into salapa elements trough the FA editor. That's it. Trying to read from ECU (read SVT doesn't work) I got tricky or mising folder names in the FDL editor (see pictures): In the fodlers tree I cannot see the names of FDL's, just points.
Is there a mistake from my part about installations , or newer sources that I can try?
Thank You for help
#1,757 · (Edited)
Hello everyone,
Thank You for help
Use Read ECU, not Read SVT. This is normal.
CAFD Data is trimmed. You need working E-Sys Launcher solution.
