Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,759 ·
#1,766 ·
Enable your PM function, and then send me one:
"bglnel has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
#1,777 ·
#1,788 ·
No. There is no such thing. Launcher PRO 3 has Online Activation by Developer only. Older Launcher PRO 2.8 has .est token. PM sent.
#1,790 ·
#1,791 · (Edited)
Hello! I'm new here.My car is BMW F10 LCI 2014 and I need help to code with Bimmercode my headlights.. So I need a cheat-sheet to make some codings with Bimmercode or what codes should be modified for these functions:
- Home Lights - active for a specified time after I exit from my car. Before , when I got out of the car (engine off) , automatically , the front lights remained on 40-50 sec. ... In present they not light up and this function it's checked in Idrive menu.(This work only if I press a button from my remote key)
- Welcome Lights - always switch on Angel Eyes (day and night) and with Low Beams (in darkness only). In present when I unlock the car via remote key , Angel Eyes lights up together with low beams even if it's a sunny day.
If a little help is possible I need these functions from a cheat sheet. In basic mode is more easy but I don't know if all of these functions will appear there to be coded.
I've ordered an OBD adapter and will come to me next days.
Thank you!
#1,799 ·
No, E-Sys is not paid. But 3rd part Launcher Application (Launcher pro or E-SysX) is.
E-Sys is Windows only.
PM sent.
