Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,938 ·
Hi Shawn,
Going back to my post above, the softwares I need in the description of that video is
Launcher Premium 2.7.x (w/ Built in Token Generator), esys, and psdz. I've downloaded and installed esys and psdz from the links you shared in your post but I'm not sure if Launcher Premium 2.7.x (w/ Built in Token Generator) is the same as Launcher Pro 3.x.
Any help would be much appreciated.
#1,939 ·
Hi Shawn,
It s the same Software, just different versions. PM sent.
#1,954 ·
#1,956 ·
Hey,
Is it possible to get a link to the latest psdzdata for a G20 (S18A-20-03-540, so it needs to be recent)
Thanks heaps :)
I replied to your same PM.
#1,967 ·
#1,969 ·
Hi Shawn,
Please could I have a link to the latest Token, Launcher and PSDZData?
It's for use on F10's 2015+ (535i/d & M5)
PM sent.
#1,974 ·
Hi Shawn I donated to St. Jude's on June 20 for Tokenmaster's access after seeing some out of date ESYS instructions online. I saw that some people said he has been responding, but I still haven't heard from him. I'm eager to start coding! Anything you can send to help?
Thanks and happy 4th!
Email him again. He was answering emails yesterday.
#1,976 ·
#1,978 ·
Hello Shawn!
Tryed to start coding my 2016 F30 with software provided on the first page of this thread, but it seems that the software won't work anymore. Do you have the link(s) for the working software that is able to code F30 with a current I-level of F020-18-11-531?
Cheers
PM sent.
