Coding: (No Request) Latest Software Links
2 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#1,982 ·
Hello Shawn,
Hope your are doing well.
Can you pleas provide the latest E-sys.Token launcher and PSCZ Software.Beginner here trying to code 2018 BMW X5 F15.
Thanks,
Ram
PM's sent.
#1,986 ·
From OP:
Sorry to be daft: does this mean that it IS hazardous to use 2.8.x on a G-series or that it SAFE to use 2.8.x on G-series?
Not hazardous. CAFD Mapping me be missing or even mismapped, but any coding can be reset.
For Gxx car, you really need Launcher PRO 3.7 or E-SysX to have the latets CAFD Mapping.
#1,996 ·
Hi Guys,
I new here sort of. I've been coming here for years. I decided to go ahead and join because this site has been very helpful to me over the years. I am having the same issues with my ESYS. I can connect to my car and do VO. But I cant FDL edit. It has something to do with the tokens. The error I get is "no EST file selected". If anyone can shed some light on this situation it would be deeply appreciated.
#2,002 ·
#2,006 ·
#2,009 ·
#2,013 ·
Hi Shawn
I’m trying to code in K235 trailer for my 2017 x5, but it’s not coding correctly as I get some cafd errors after coding. I may have an older psdz data file.
Can you send me the latest psdz and e-sys(just in case) please?
Also, can I get away with the lite version for the trailer coding or do I need the full version?
Thanks in advance!
#2,014 ·
Hi Shawn
I'm trying to code in K235 trailer for my 2017 x5, but it's not coding correctly as I get some cafd errors after coding. I may have an older psdz data file.
Thanks in advance!
Coding always only requires Lite version. PM sent.
#2,020 ·
f you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full. PM sent.
#2,021 ·
Hi guys.
I installed months ago e-sys but I didn't succeed in activation (I sent request but had no answer).
Someone could help me, please?
PM sent.
