Coding: (No Request) Latest Software Links
10 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,065 ·
I could use the links to code my 2020 X5.
Greatly appreciate your dedication here Shawn!
#2,075 ·
Hello,
I had coded my car a few years back, and had some major service done which resulted in the coding being removed/updated.
When trying to code the vehicle I encounter the following message, which I suspect is resolved with the newer software versions.
Code:
Transaktions-Report:       Aktion: Codierdaten lesen
CAS [40] [C808521]
readCPS o.k.
CAFD_0000000F_005_025_058 Fehler:
File for "cafd_0000000f-005_025_058" not found! [C012]
Thanks in advance!
#2,078 · (Edited)
Hey!
I want to update/flash the latest ISTEP level of my car (F87) via E-SYS. I already have the full data from Shawn. I understand that to flash, it's best to use the latest version of E-SYS, is that correct? So in this case: E-sys 3.33.4. Is it also correct that to flash/update/program the ECUs you don't need a launcher?
Thanks in advance!
#2,080 ·
Hey!
Thanks in advance!
Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. E-Sys Launcher needed for FDL Coding inly.
#2,081 ·
G14 FDL coding
Hi all,
I'm trying to code a few options like video in motion on my G14
I have launcher pro 2.8 and the latest psdzdata for the vehicle,
when I detect the Caf file it only gives numbers and not a description.
Is there any way to get the descriptions up within these files to enable fdl coding.
Any help would be greatly appreciated.
#2,083 ·
Hi all,
For new Gxx car, you likely need E-Sys Launcher PRO 3.7 or E-SysX for the latest ECU CAFD Mapping and these can only be obtained from the developers direct.
#2,082 ·
I just had to replace the engine on my 2014 Alpina B7 and I think i need to recalibrate or relearn the fuel injectors. Also now im getting a parrisitic battery drain that kills a new battery in less then 24 hours. Could you help with the software needed for diagnostic and calibrations. I would also like to see what coding I can do on her.
Jim
#2,085 ·
Thanks Shawn
Do you have a link for where I can get launcher pro 3.7 I've been on tokenmasters website, but cannot find how to get the software.
Many thanks
Link is useless as it can only be activated by developer TM himself, so you must get from him.
#2,095 ·
F10 LCI OEM Reversing Camera Retrofit Coding
Suggested to redirect my question here by wcrd3
I have a 2015 F10 LCI 520d, having previously had a 2011 non-LCI and also a 2008 E60 LCI.
I have just got the car and it has nearly everything that I want including folding mirrors and Harman/Kardon sound system which I never had before. My first project is to retrofit an OEM reversing camera into the car. I have the retrofit kit(66212181317) and the camera ECU(9354002D). I think all I need to do is install and code.
I'm pretty happy that I will be able to install with no major issues, but when it comes to coding I am not sure if I need help or not.
I have an ODB + Bimmercode, and also Carly dongle + App. I have coded a few options already e.g. Sport Automatic Transmission and Digital Speedometer, but all in simple mode in Bimmercode.
I would be pretty confident that if I knew which parameters needed to be updated in Expert mode on Bimmercode, I could code them. I have a software background.
My question is: Which parameters need to be changed? Any help greatly appreciated. I have searched for this in a few placed but I havent been able to find exactly what I'm looking for. Please excuse me if this has already been asked somewhere!
Cheers
#2,098 ·
Cheers
You should just need to add 3AG to FA and VO Code car Head Unit and Camera.
#2,100 ·
Hello All,
So i am trying to program TJA on my i3, got the Quizdel dongle and trying to get access to launcher pro and e-mailed fxxtokenmaster@gmail.com but havent gotten a response.....
Any help will be appreciated. thanks!
#2,111 ·
does anyone know what the HEX code is for TJA speed limit of the i3? I know is 63 and 3E of 62mph. I want to try a higher speed...like 75 mph
#2,114 ·
Wrong Thread. As Thread Title, "Fxx-/Ixx-/Gxx-series PSdZData FULL Requests (Programming Firmware)", indicates, it is for PSdZData Full, not Lite. PM sent.
