Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,287 ·
  • Like
Reactions: HeimdaIl
#2,290 ·
#2,293 ·
Finally got everything to code, not sure if it’s actually working though. At first test, the gate wouldn’t close with FOB or button, not sure if I have to allow the car to power cycle, but I do know the writes to the ECU have taken.
also, I’d like to point out that using the latest free launcher app, you must specify medium memory use or the modules will be only periods. Found this info in a forum post not in any guides. Cheers, thanks for everyone for all the info.
#2,299 ·
So still no mirror fold in, be it with holding the lock button on the fob or holding the touch area on the handle. Everything else I've done works well. (I do have electric mirrors, I promise). Windows also don't roll up when holding the lock button (strange.) Will keep trying.
What exact FDL Codes did you make?
#2,301 ·
You need these:
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv
KOMFORTSCHLIESSUNG_FB = aktiv
KOMFORTSCHLIESSUNG_PA = aktiv
KOMFORT_SCHLIESSEN = Werte 00 (Werte Value must be changed directly, not via Dropdown box)
#2,303 ·
If you have FEM, they are all in there, Use search bar and search for KOMFORT_SCHLIESSEN (no leading or trailing spaces).
The first 4 are changed via Dropdown Box, and last one is Direct Werte Value change. If for any you changed both the Dropdown and the Werte, coding will be screwed up.
#2,307 ·
Yes, I wrote if you have FEM.
If you have F25, then codes are in FRM and CAS.
For Werte Value Chnage:
E-Sys - How to Change Werte Values.pdf:
#2,325 ·
TM comes and goes like the wind.
Use E-Sys Launcher 2.8.2 PRO BFU Edition from here:
From TokenMaster's Blog:
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST
Posted by TokenMaster at 6:16 PM​
Links are there:
E-Sys Launcher PRO 2.8.2???
