Coding: (No Request) Latest Software Links
12 reading
1.3M views 6.2K replies 2.1K participants last post by  guns03
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,380 ·
Hello Guys,
Could you please send me the link for the latest Esys, Launcher and the psdzdata?
I tried to vo code my f20 but my psdzdata are too old.. So im gonna reinstall all the lastest software ✌
PM sent.
  • Like
Reactions: Reikari
#2,382 ·
#2,390 ·
  • Like
Reactions: Teush1980 and Jppv
#2,395 ·
Hi Shawn/All Thank you for all of your posts! I've been trawling with the help of them I've successfully been able to retrofit 6wa from basic kombi, HBA, Trailer Module, and I'm just about to get started with a CIC > NBT retrofit!
I wondered if anyone could help with a link to an ISTAP installer (I have 63.3 Psdzdata downloaded which took the best part of two weeks lol)
Thanks,
#2,396 ·
Thanks,
ISTA/P is E-Series Programming only. This is what you need?
#2,412 ·
No. You download all parts to same folder, then Open and Extract ONLY part1, and all parts will be extracted automatically.
#2,418 ·
#2,422 ·
Sorry, I cannot help with ISTA, Thread as Title indicates is for Fxx-/Ixx-/Gxx-series "Coding: (No Request) Latest Software Links", which is not Diagnosis / Programming such as ISTA. PM sent.
  • Like
Reactions: Theo325
