Coding: (No Request) Latest Software Links
6 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,582 ·
Hi Guys!
I've got the following problem:
I have installed E-Sys 3.28.1 which worked fine in summer when I used it the last time. Launcher is Launcher Pro 3.0.4.90. But since yesterday there comes the message in Launcher Pro "This application requires an activation code. If you don't have one you may login to fxxtokenmaster.com to request one. Well I tried but there I can't find one on the site. It says "You do not have any active key. Contact TokenMaster to request a key. "
Could anyone tell me what to do? All I need is to be able to code again.
I also tried to download the 3.27.1 because I thought this works without launcher but it doesn't (missing EST File).
I already tried to find the solution by reading here and fxxtokenmaster blog but I think I haven't understood what the current steps are.
Thank you so much!
#2,584 ·
No idea why your Launcher PRO 3.x Activation is jacked up, but only TM can resolve. Short of that, you would be stuck using older Launcher PRO 2.8.2..
#2,585 ·
Unfortunately he doesn't answer to emails. So it seems to be an issue with this version of the launcher I think
A friend with the same configuration has the same problem...So it seems to be an issue with this version of the launcher, I think.
Where do I get Launcher Pro 2.8.2? Is this a free version? How does ist currently work with getting Esys? Is it still with a donation to TM? As I can see you've got links for the current version.
#2,587 ·
From TokenMaster's Blog:
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST
Posted by TokenMaster at 6:16 PM​
Links are there:
E-Sys Launcher PRO 2.8.2???
#2,589 ·
Oh... of course... Shame on me! I've already found this, yes. Therefore I would have to uninstall my 3.0.4.90 right? Are there any disadvantages with the older launcher? Will it work with esys 3.28.1?
Thank you!
Older version will not have as current CAFD Mapping as newer version, so maybe some ECU CAFD that worked, will be trimmed in older version.
#2,593 ·
I use E-Sys 3.27.1 for coding and 3.30 for CAFD injection and flashing. No need nor benefit for any newer E-Sys.
#2,597 ·
  • Like
Reactions: Marracoonda
#2,606 ·
PSdZData is all F/I/G Series combined. There is not a main module per se' although there is a Gateway Module (ZGW, FEM, or BDC).
#2,609 ·
Hey @shawnsheridan
Few quick questions. I had coded my X4 a few years ago but just had the software updated to f025-20-07-540, which wiped everything.. :( to recode I assume I will need new PSdZData lite
Can I still keep using e-sys 3.27.1 and tokenmaster launcher v2.8.2.1555 to code. Or do I need to move to a newer version.
I have done the rearm was was able to open it all but a few of the svt modules don't load, such as CAS. I just get an error not found.
Please pm me anything I might need... if you don't mind.. many thanks.
#2,610 ·
Hey @shawnsheridan
You should just need PSdZData update. PM sent.
  • Like
Reactions: saber007
#2,616 ·
Clear Fault Codes with E-Sys:
Click "External Applications" in the left menu.
Click "External Application"
Double-click "Transmitter"
Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS – DM_Lock,clear ZFS – DM_Clear,ZFS – DM_Unlock)"
Click Connect
Click Send
#2,624 ·
Links are there:
