Coding: (No Request) Latest Software Links
4 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,749 ·
Hi,
i try coding a G05 2019, but i get some error massages.
is it possible to coding this with e-sys 3.30.1 and Launcher Pro 2.8.1.155?
connetion to the car is ok, but i cant read out the SVT via VCM (Error: C105) only via ecu.
try read out coding data: error is (C012) CAFD File not found.
anybody knows ehat is wrong?
thanks for help :)
Kai
#2,750 ·
Hi,
thanks for help :)
Kai
Esys 3.30 is to old, you need newest one
#2,782 ·
Hi Guys apologies for my lack of knowledge and a long post . Due to fear of killing my car a 2015 F15 X5 3.0d msport I have only used Carly and Bimmercode for coding. About 4 months ago Shawn Sheridan was very kind and sent me E-sys pro laucher 2.8.2 build162b bfu edition with psdzdata 4.25.21 with E-sys 3.27.1. At a recent garage visit my car was updated to istep F025-20-03-540 and some of my coding mods where overwritten. I have eventually got up the courage to want to learn to code properly with E-sys things like enhanced Bluetooth for text messages etc. So I need to know if the software etc listed above is still adequate or do I need newer versions. Many thanks in advance for your patience and.guidance.
#2,787 ·
Could I please have the latest psdzdata for BMW G30 520d Xdrive and token if needed please? Not sure if I'll need token to code the ambient lights(to different color) and HU to HIFI... but I'm pretty sure I would need it in order to flash my gearbox to newest version... still trying to figure out how to do that as I'm new to this and would take any sort of help, is there a cheat sheet? Thank you very much
