Coding: (No Request) Latest Software Links
7 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#2,892 ·
All you need is here:
From TokenMaster's Blog:
UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST
Posted by TokenMaster at 6:16 PM​
Links are there:
E-Sys Launcher PRO 2.8.2???
  • Like
Reactions: Hetr
#2,896 ·
Does anyone know if I can code '21 F40 with Esys 3.27.1? Or should I use EsysX? If the latter, are there instructions available or is the process same as esys?
Use E-Sys Launcher PRO 2.8.,2.. If any ECU CAFD is not mapped, then you will need E-SysX.
Does anyone no what category I should use for a F40? its not covered in these instructions below..
TE: F001 psdzdata covers: F001/F002/F003/F004/F007/RR04/RR05/RR06 (5-Series GT is an F07 NOT an F10) F010 psdzdata covers: F005/F006/F010/F011/F012/F013/F018 F020 psdzdata covers: F020/F021/F022/F023/F030/F031/F032/F033/F034/F035/F036/F080/F082/F083/F087/F088 F025 psdzdata covers: F015/F016/F025/F026/F085/F086 F056 psdzdata covers: F039/F045/F046/F047/F048/F049/F052/F054/F055/F056/F057/F060
S18A
F040/F042/F044/F091/F092/F093/F095/F096/G005/G006/G007/G009/G014/G015/G016/G018/G020/G021/G022/G023/G024/G026/G028/G029/G042/G080/G082/G083/G087
  • Like
Reactions: akz_g
#2,897 ·
Links are there:
You cant get Launcher Pro 3.x.. If Pro 2.8.2. does not work, you will need E-SysX.
#2,895 ·
#2,901 ·
Hello,
I have problem of airbag blinking light after ACSM ecu upgraded. It seem I need eDiaBase Tools with lastest ACSM5.prg,
Where can I found it please ?
PM sent.
#2,902 ·
So I hooked up Esys to my F40 for the first time. Managed to connect successfully. I followed the normal coding process that I've done for my F22 but it seems some things were different. I was searching for 2 items; ASD and VIM..Trying to achieve sporty setting in ASD menu and VIM. However the folders didn't have the name, just numbers so im not sure where to look for my settings to change. Is this some sort of mapping missing ? Screenshots below:
1028480
1028481
Am I doings something wrong? Am I looking in the wrong place?
Any advise will be very much appreciated!
#2,903 ·
PM sent.
#2,912 ·
Hi all,
I'm back after several years of absence, with a Mini Countryman F60 my 2019.
I coded the car when I bought it, but now I would like to modify some things that seem to no longer work as before after an update in BMW.
I tried to do something but I have a problem probably due to old psdzdata (4.27.31). Where can I find the latest?
Anyway, the error occurs when I try to read coding data on any ecu, for example this one comes from ACSM2 CAFD_000011AB_007_003_010 Fehler:
File for "cafd_000011ab_007_003_010" not found! [C012]
thanks and best
Luca
#2,929 ·
Injecting CAFD (Detect CAF for SWE) and Flashing ECU's with >= v.4.17.20 PSdZData requires using newer E-Sys 3.30.0 or higher. PM sent.
#2,941 ·
