Coding: (No Request) Latest Software Links
3 reading
1.3M views 6.2K replies 2.1K participants last post by  spadae2
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#3,734 ·
Hi to everyone!
I have mad allot of nice things using E Sys , and i neet to thanks again Sean for this! Now i want to update the maps ! Can anyone explain how to do that,and what i need? Can be done also with E Sys? Thank's!
PM sent.
#3,748 ·
Hi @shawnsheridan
would it be possible for you to send me the current links as well? My F11 seriously needs some coding done :)
Hello Shawn,
Do you have a link for E-sys launcher that will work with E-sys 3.27.1? I have to recode my FDL changes (F36 from 2016) after my latest service reprogrammed the entire car. As you know, E-sys Launcher Premium is no longer usable. I appreciate your help!
Looking for the latest E-sys and PSDZ if someone could hook it up. Thanks!
Looks like I need to tag the man himself @shawnsheridan
Cheers
PM's sent.
  • Like
Reactions: flogger
#3,753 ·
@shawnsheridan Hi Mate, I'm new on the BMW scene and I recently bought a F36, I'm retrofitting a few things. I've just installed the M4 Folding Mirrors and I can't seem to find the right software to do it. Next I'll be retrofitting the reversing camera and I've thought about HUD also but that's going to cost allot to do so having secong thoughts.
Just as F10girl said; You seem to be the main man round here! Any chance I could get the latest psdZ data, Esys, and Launcher? Thanks so much
#3,755 ·
#3,756 · (Edited)
I need to download the following CAFD files to redo my coding on my 2016 F36 as I cannot read the coding data from the car:
CAFD_00000909_005_003_001.ncd
CAFD_00000794_018_070_005.ncd
CAFD_000007C8_007_001_015.ncd
CAFD_00001EF6_006_025_106.ncd
CAFD_000009C8_008_000_020.ncd
CAFD__000007A1_005_044_018.ncd
I have tried to download and extract v.4.34.40_PSdZData_Lite .rar, howeverWinRAR inidicates that the archive is either in unknown format or damaged. Can anyone help?
P.S. I think I have the problem solved: a new version of WinRAR was necessary. As long as the CAFD files are a match, I should be good to go.
#3,769 ·
Yes.
