Coding: (No Request) Latest Software Links
6 reading
1.3M views 6.2K replies 2.1K participants last post by  shawnsheridan
#1 · (Edited)
What is Included:
  1. Software Overview and Requirements
  2. Latest Software Links & Installation Instructions
NOTE1: URL Links are in BLUE and pictures are links to larger images.
NOTE2: Click here for Getting Started Guides, Tips, & Cheat Sheets
1. Software Overview and Requirements:
This guide serves Fxx, Ixx, and Gxx-series vehicles. For E-series, different software and cable are used. Complete Software & Interface Overview.
Supported Chassis Code Overview
Prerequisites:
  • Windows 7+ Computer.
  • E-Sys = Main Coding Software
  • PSdZData Lite(~2.5 GB) = ECU Data Files. Works for VO & FDL Coding.
  • Bimmer Utility = Provides License (ie Activation), FDL-Coding mapping, Cheat Codes (Section 7), & other optimization.
  • Connection Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM. For computers without an ethernet port, you can use USB-to-ethernet adapters
2. Software Installation:
NOTE: Links never change. The latest versions are usually found below.
  • Add a comment to the thread if links down or you need newer versions
E-Sys - Install Instructions - v.15.pdf (Guide courtesy of member Shawnsheridan)
Bimmer Utility - Mapping 4.35.42 - Only and recommended solution
  • Auto-updated and supports the latest mapping for the most accurate coding experience
    • Purchase directly from the developer's website.
  • E-sys 3.39.1 - Used with Bimmer Utility or alone for Programming and VO coding.
Latest PSdZData_Lite (~2.5 GB) WORKS FOR ALL FDL CODING & VO CODING
  • Use this guide to determine your I-Step.
  • You only need one lite version for coding that is equal to or greater than your I-Step.
    • NOTE: If you get a "Not Found [C012]" error when "Read Coding Data," it is time to update.
  • Do NOT merge. DELETE old PSdZData folder & REPLACE w/ new PSdZData folder.
By Resource:
  1. NCD / CAFD: Read *.ncd files offline and easily search for a function, viewing current settings as well as other options
  2. NCD Compare: Load *.ncd files using Folder icons or drag & drop and then the far right button initiates compare. Popup showing Left vs right values which you can highlight and copy if you choose. It also highlights *.ncd trees differences in red & you can scroll up and down.
  3. Decrypt CAFD: not just for CFDs. It also works for other Psdzdata files (eg FAFP).
  4. FA / FP: viewer; tool includes mapping (eg 430 Inter Exter mirror anti dazzle). You can search loaded FA or entire FAFP (ie available options). FP viewer allows you to view options by Vehicle Profile (FP) without loading FA (Vehicle Order).
  5. FA Compare: like #2, but comparing fas.
  6. FA-CAFD: You load individual ECUs *.ncd and can see how FA additions will affect (ie "what-if).
  7. SVT-CAFD: You load the entire saved SVT file and see how FA changes will affect (ie "what-if).
#4,014 ·
I'm trying to get back in this "game". Forgot a lot of it over the years :p
Can I use Esys without Bimmer Utility or any other additional component if I just want to extract a 1B file for use in another application?
Thanks in advance.
Yes. BimmerUtility needed ONLY for FDL Coding.
#4,017 ·
For FDL Coding, E-Sys requires a 3rd Party “Mapping” application such as BimmerUtility as it Provides CAFD Mapping. BMW AG made changes to PSdZData beginning with 54.2 PSdZData where they removed (trimmed) all descriptive text from CAFD and FAFP files, making FDL Coding of ECU's difficult, as the FDL Codes can no longer be easily located. The "Mapping" application dynamically maps the trimmed data back into CAFD file making FDL Coding possible. BimmerUtility is NOT needed for VO (FA) Coding nor ECU Programming (Flashing) as these can be performed with E-Sys direct.
  • Like
Reactions: mrpingu
#4,026 ·
Guys, my E-Sys is not working anymore. I have updated on a F30 the tempomat buttons from limiter. Has to code now that thing but my E-Sys is not working anymore. Don't know why. Have seen there is a new version. I have downloaded the files on page 1. Do I need also some kind of tokenmaster prog to start it? Can you please help me getting it working again. Thank you in advance!
Denis
#4,028 ·
Denis
PM sent.
#4,030 ·
#4,032 ·
#4,047 ·
#4,050 ·
  • Like
Reactions: Davem3e30
