1 - 9 of 9 Posts
Hi, ive recently took out my egr and now EML light has came on. So how do i code out the egr?
Discussion Starter #3
The M54 does not have an external EGR valve, it has internal EGR, and cannot be removed. What you removed was the secondary air valve used to heat up the cat quickly during cold start up. The secondary air does not effect the engine power at all, and turns off after the cat is warmed up.
I don’t believe EGR can be coded out with INPA. You’ll have to remap the DDE with a professional tune. Might be easier just to reinstall the EGR.
OP’s engine is a diesel.
Pre cat o2 sensors
So I got an after markers header after my cats went bad but my headers only had one bung at the bottom which is where I connected the foulers and my post o2 sensors but now I just have my pre cat o2 sensors Zip tied off to the side for the time being and I***8217;m not sure what to do to fix it. If you have any suggestions lmk. Thanks
1 - 9 of 9 Posts
