1 - 4 of 4 Posts
I am trying to program a used N18 DME and cannot find the correct ZUB and part number in WINKFP. It is a MVD1722 with part number 7639.... Has anyone run into this issue? Is there something I am missing?
hi,
To align a used DME there is more involved than programming the correct ZB number, Did you adress ISN (immobilizer) as well?
Discussion Starter #3
Yes, I have programmed a used DME before using the BMW Coding Tool and WinKFP. I need to change the VIN first but I cannot find the right ECU family with the correct part number.
you can get the current ZB in INPA. with this ZB you can get the correct ecu family and search out the correct one for your car/options. But on this car you have to align the ISN as well, this is not possible with BMW standart tools also some Mini DME's are FSC protected.
1 - 4 of 4 Posts
