2008 4.8i. New Arnott air springs, new blue (right, replaced due to hose damage) air pipe, new fittings. Air bags hold air. I can't squeeze any air out. Suspension has a super slow leak. (Only noticeable now that I'm not driving much. Right sags a little first, followed by the left). Soapy water reveals no leak at the bag fitting and no leak at the valve block fittings. In my mind that leaves the valve block and and compressor. While still installed I sprayed soapy water on the entire valve block from underneath and did not see any bubbles. It's impossible to see the top. I also sprayed the hose fittings from the compressor to the valve block. No bubbles. I have seen a YouTube test of the valve block being submerged but it would be great to hear about another way to test the system. I think I have ruled out the fittings, bags, and pipes. Anyone have recommendations? Compressor still pumps, ride height is correct. Compressor and valve block is original at 170,000 miles.
Rebuild valve block with new seals? Rebuild compressor? I HATE replacing items before seeing the reason.
