Hi again
, have been carrying out compression testing on my 1997 520i and note that each cylinder (while hot) is giving a reading of around 105 psi (+- 2psi) does this sound right?
When I'm testing compression sometimes the pressure drops and then jumps up again as if i'm losing pressure elsewhere, can this be caused by a vacuum leak?
I intend to check it again when the engine is cold.
Thanks in advance :thumbup:
