1 - 2 of 2 Posts
all sorts of internal wiring issues following low speed row with wall;vol on steering wheel non functioning,some dash warning lamps out, clock no longer display's, A/C controll is no longer connected to compressor ( but will blow cold when i take power from jumper point and put directly on compressor) , reversing light out, indicator relay no longer ticks inside but functions at the bulb end ? any advice well recieved down in south of france
Now if we only knew which corner/end of the car you crunched maybe we could come up with some good ideas.
If it's the pass side front, look at the ground shoes under the hood that is bolted to the inner fender? It's a ~50mm x 50mm black plastic piece with lots of brown wires connected to it.
If it's the pass side rear, look in the trunk above the battery? Lots of relays and fuses in that location.
1 - 2 of 2 Posts
