Contemplating eDrive 45e Purchase -- Questions
1525 Views 47 Replies 11 Participants Last post by  speedyman
Contemplating picking up a 23MY X5 xDrive 45e before they transition to 24MY. Would greatly appreciate any insight into the following questions:
1. Have found a pretty close match to what I'm looking for, but this particular vehicle does not come with Parking Assistance Plus. Will the X5 still have a backup camera and some baseline level of park distance control? Curious if mostly what is lost is the 360-deg views.
2. From the limited info on 24MY currently avail, any good reasons to wait? I'm not a big fan of the 'all in unified display' controls and the extra 100 HP wouldn't sway me, though it might be interesting if the electric motor HP/torque jumps substantially. Does anyone know if that's the case?
3. Most color combos available are either the Jet Black or White. Can any current owners comment on paint longevity? In the past I've shied away from these colors because they seem difficult to keep clean and they tend to show swirls easily. If you own these colors, would you take it through a car wash?
4. The vehicle seems amazing. Have watched numerous videos regarding ride quality, hybrid drive, and Harman Kardon system. That being said, any 'buyers remorse' or big lessons learned from this vehicle?
Appreciate all. Posting here since several of the questions relate to X5 vs. 45e specifics. Thanks!
See less See more
1 - 20 of 48 Posts
Forget about a '23 45e. The X5 50e goes into production next months and has very significant upgrades but that is if you are set on a PHEV. There is a significant amout of info on all the LCI models at this point.
Understand that any electrified vehicle will become relatively obsolete in the near future as this is a very rapidly evolving and advancing technological arena as in Bag Phone-Brick Phone-Flip Phone-Smart Phone-4-6-8-10-.......
Get what is current now and not what was the player 4 years ago which is ancient history in that world. Your depreciation is going to be steep on a 45e as the 50e takes center stage.
You will be moving a 6,000 lb vehicle with 110 HP from your overnight charge with a 45e in pure electric mode for about 30 miles max. That HP has leaped to nearly 200 HP with the 50e but keep in mind that the power to weight ratio at that point is still poor at around 30 lbs per HP.
See less See more
Thanks @speedyman - great info.
Personally, like the interior of the '23 better...but your stats on hybrid drivetrain are appreciated, especially with pace of technological change as you mentioned.
Still curious about what driving aids for reverse are available w/o parking assistance plus. Camera? Sensors? Just not 360-deg views?
See less See more
The vehicle will have a reverse camera and rear PDC...I'm not sure if there will be front PDC without the extra package. The feds in the USA require a reverse camera on pretty much all vehicles since about 2019 or so.
  • Like
Reactions: 1
Quite a few folks have been buying the 23's due to the interior changes in the LCI so you won't be alone. The quicker charging is the big advantage of the 50e, the HP, and small torque increase, will make little difference in daily driving in electric since the way it is set up it will only come into play at higher RPM's.
All of the parts will get scratched and show swirl marks depending on how you wash them. Use a touchless and you should be fine, run it will brushes and will likely get marks. Choose the color you like. ;)
Good luck with your decision.
See less See more
Current 45e is 389HP/443TQ, the 50e will be 490HP/516TQ. This is going to be a very noticeable increase in power.
Those numbers are not what I was referring to but rather driving in electric.
Some analysis that has been posted from a European enthusiast:
Regarding the new E-Motor...don’t expect a big wonder. The new motor has just 20Nm more torque ( 265Nm vs 285Nm) .
That more power is just over 3000-5000rpm significant, as the new one can hold the torque up to 5000rpm ( old one up to 3000pm).
The question is how will BMW change the gear shifting logic. Currently the shiftpoint is at approx. 4000rm .
After that the torque is falling sharply down and it makes sense to shift into the next gear. It means, that if the ICE has to jump in ( e.g. kickdown) , then it hast to rev up to max. 4000rpm.
So if the new one will go up to over 5000, then it will be a huge jump for the ICE.
That range is currently not even accessible if the engine is cold ( max 5000rpm allowed).
I expect, the more electric power will be a game changer in the hybrid mode, but not in the EV mode.
Currently, the E-Motor could deliver up to 265Nm so it would be possible to reach the 700Nm in the range of 2-3000rpm, but BMW want a wide torque plateau, and therefore it's reduced to 150Nm ( which can be delivered at 5000rpm too).
The new one can put down 250Nm in the full range, and so you will have +100NM in Hybrid mode, which is more then noticable...
Yes, I meant that it won't make a big difference in the lower rpm range in EV mode.
265Nm at 3000rpm are 111hp and 285Nm at 3000rpm are 120hp. Shiftpoint is currently at approx. 4000rpm, so if you accelerate hard, the used rpm range is between 3000-4000rpm .
So in other words, if we would put that engine in the current 45e, we wouldn't notice a big difference. Above 3000rpm obviously looks better.
But in hybrid mode there is a 100Nm plus over the whole rpm range, and that should push down the 0-100 times by approx. 15% (4,7-4,8 sec)
See less See more
Yeah, I get that explanation and Thank You. I can't imagine driving a 6,000 lb vehicle in a 200 HP puss mode when I paid for something with nearly 500 HP.
There does not appear to be a run on the '23 45e with over 450 of them nationally looking for a home.
To indicate that there is some kind of a rush on what will soon be the previous configuration is a bit disingenuous.
Sure, there may be a few out there here who have some aversion to change and the interior upgrades in technology and overal layout of the LCI which is in line with the current trend across many manufacturers.
There will always be guys who wish their trusty "flip phone" and Window '95 was still viable. Large displays are the current trend and will be accepted by the overwhelming majority of new car buyers with the exception of the "old school will always be better" fist pounders. That crew is more than welcome to live in the past.
See less See more
  • Like
Reactions: 1
LOL Sorry, I don't play your nonsense games. Go find find someone else.
See less See more
No my friend, nonsense is promoting the misconception that those in the market for a new X5 are scrambling in mass to be buy what will be outdated technology and yesterdays news in a couple months. That is just ridiculous. I really doubt if anyone else is buying that BS.
You seem to see yourself as some ultimate authority on all things BMW here.
See less See more
LOL - One day you will grow up. You do realize no one falls for your immature attempts at goading people into arguments. At least try a little harder and not blatantly make things up. Perhaps find an elementary school playground, they may be more on your level.
See less See more
Well OK then, I will take every word you type on this forum as Gospel from now on so you don't have to resort to personal aggression. Pretty sure that I am not the first to notice that you really do not like to be disagreed with.
I find it comical how you seem to believe that you know what every BMW buyer is thinking and what every BMW dealer is selling their units for.
See less See more
Appreciate the input received.
Decided to pull the trigger on a ‘23 xDrive45e in Dark Graphite Metallic with Silverstone interior. Key factors were better value (comp to ‘24MY), prefer current interior, and use case doesn’t point toward benefit from ~100+ HP increase. Likewise, delivery this week likely means ability to squeak in under Early 2023 EV tax credit rules before IRS reissues guidance (rumored to be sometime this month).
Appreciate the wealth of info gleaned from this site. It’s been a few years since my last BMW (650ix) back in 2017. Looking forward to it!
See less See more
  • Like
Reactions: 3
Congratulations! Good luck, enjoy and be safe.
See less See more
That sounds amazing! Congrats!
See less See more
1. It has an excellent wide angle backup camera, with projected track lines. I have the parking assist rairly use it. I would highly recommend the surround view, not sure what package it comes with but I love it when parking.
2. For me any vehicle capable of sub five second 0 to 60 is plenty fast for some others there is no such thing as too fast. In deciding between model year factor in future resale, one will always be a year older with yesterdays tech.
3. I would respectfully disagree with your color assessment, IMO, black is the fastest to show dirt White on the other hand is very forgiving. I have a nearby hand wash that is very reasonably. But I have used car washes in the past without seeing any damage.
4. The vehicle is amazing.
See less See more
Yeah, black looks dirty with the slightest dust or mud...one of the greys is probably a little less problematic.
While I sort of like metallic paints, it is really hard to get an exact match with them should you need any eventual repair. It's much easier to repair or touch up a single, solid color versus a metallic.
See less See more
I order the 23 x5 45e over the 24 do to one reason. $$$$$ the way I wanted it equipped the 23 was $79675.00 the 24 was $86,000.00 + similarly equipped. But with the tax credit and negotiated discounts my cost on the 23 will be just under $70,000.00 plus sales tax. On the 24 the dealer wasn’t willing to negotiate either but I didn’t pursue so who knows. But it cost me at least $16,000.00 less going with the 23. What ever you get good luck
See less See more
  • Like
Reactions: 2
1 - 20 of 48 Posts
