1 - 4 of 4 Posts
hey guys, im planing to drain my radiator (half radiator from the red knob top halve)
for thermostat replacment on my e64 m6 2009.
after iwill drain it and fill the coolant tank to the maximum how should i do the coolant bleed?
is this the same procedure that i found on youtube for most bmw cars?\
(open ignition when engine off, turn on the heat on lower level and than press the accelerator pedal for 10 sec?
or its different procedure on my car?
thank you so much!:wink
Discussion Starter #3
Super Moderator
Yes but don't forget the temp control settings, that's an important part.
1 - 4 of 4 Posts
