1 - 1 of 1 Posts
I, recently, had a mysterious coolant leak coming from a weep hole near my water pump in my 2009 550i. After calling around to several auto shops, the price seemed like it would be steep to fix the issue. The coolant was actually coming from the front seal of the coolant transfer pipe. After a little digging online, I found an easy, inexpensive fix. It is called BimmerFix. It only took me about an hour and all I had to was access the water pump and remove it and put in a stent to seal the leak. There is a website and it is easy to order. I hope this helps some of you that have older BMW's like mine. Apparently, it's a common issue in several models.
1 - 1 of 1 Posts
