1 - 3 of 3 Posts
Hi guys and gals, anyone knows where the coolant temperature sensor (not the coolant level sensor) is located on a 4.4 litre twin turbo engine ?? There is too much crap to pull off and start looking, if anyone knows, that would be great and minimise pulling everything off the engine to locate.
You have a radiator outlet temp sensor on the hose coming out of the radiator on the passenger side.
Separately you have coolant temp sensor under the alternator and below/next to the turbo aux coolant pump but above the water pump.
Discussion Starter · #3 ·
Thank you so much. I have seen the radiator outlet one, but I couldn't see the other one. It was very hard to see under the alternator. I appreciate your help, you have answered my question. Have a great day.
1 - 3 of 3 Posts
