I'm replacing my rear suspension with Bilstein B8 shocks and Eibach Pro Kit springs but I'm not sure about the correct bump stops to use. The shocks didn't come with any bump stops so I ordered a set of OEM ones that I'm pretty sure are far too large - they prevent over 50% of the travel distance of the shock.
So my questions are:
a) Are they too large?
b) If so is cutting them shorter a good idea? They seem quite specifically engineered with conical ends - cutting them would remove this at one end - does this matter?
c) Alternatively, are there any suitable stock bump stops from another car that I should use instead?
Photos of the bump stops on the new shocks attached, any advice would be greatly appreciated!
