1 - 4 of 4 Posts
1. Anyone know where I can find the power adapter for the glove box so that I can hook up a phone charger to it? Someone here tipped me off on it, but all I can find is the flashlight part itself.
2. Car in reverse, the passenger mirror turns down automatically, but does not return to my preset. Working as designed? If not, what can I check?
3. Done some research on replacing the fog light bulb, but I'm a little stumped when I actually go to do this. Maybe I'm dense? I find this a little difficult to do. Any tips? I have just the "regular" bumper I suppose....
Thanks guys...
Get left...Go Fast
#1 - Ebay has them..be sure to get the right one for your Model car
http://cgi.ebay.com/ebaymotors/BMW-...tegoryZ33712QQihZ010QQitemZ200131350631QQrdZ1
#2 - Hit the Memory button...mine did that a couple times too. seems to get stuck sometimes..I just don't use that feature unless I need to parallel park.
#3 - You need to remove the grill on the side of the fog light to get to the screw that holds it in place. Do a search of this forum and you'll find a DIY.
1.) I think it's a European style plug, check this or something similar: http://www.boxwave.com/products/acadaptercar/index.htm
2.) Mirror should return, if you leave the switch that selects either the right or left mirror in the left mirror (passenger) position, the mirror will at least not move when you backup.
3.) The part of the bottom grill (black part) next to the fog comes out with the removal of a screw I think (or push pin). This allows you to get the fog out, remove the back of the housing and replace the bulb. It's pretty simple and there should be a DIY writeup on this site.
Discussion Starter · #4 ·
Guys, thank you...Time to go outside and play :)
1 - 4 of 4 Posts
