We have had the 2012 E93 328 for close to four years now, and have put on about 38K Miles since getting it around 17K miles.
The CPO warranty is up in a two months, and it is decision time now.
This is my daily driver and has gone through most of the depreciation.
The car has been relatively trouble free so far. Apart from the regularly scheduled maintenance (brake line flush, oil change, filters etc.).
The car will be driven about 7-8K miles per year
- The Airbag recall done
- The wheel electronics were replaced (was getting intermittent errors of TPMS disabled) under CPO
- While doing the TPMS they also found an oil leak and replaced the Valve Cover Gasket.
- Two years ago the roof was reconditioned to fix a water leak.
- Switched to Bridgestone Driveguard Runflat tires to make the ride a bit softer
- Is there anything specific I should get checked out for fixing before the CPO warranty ends?
- What should I expect in the next 15-25K miles in terms of repairs and maintenance costs?
- I presume the 328 N51 engine does not suffer from the issues with the 335 engine?
