1 - 4 of 4 Posts
I found one of Crank position sensor, the one on the bell housing that's essentially right under the center of the car. It's corroded and cracked. Whew! Those things are expensieve! BavAuto wants 100.00 for one. Bav says 2 per car. where is the other one?
Discussion Starter · #4 ·
AlarmedBread said:
http://bmaparts.com/item.wws?sku=BMW025452++++++&mfr=FEBI+++++++++++&whse=007&cookieID=1UF0NVK4O1V71BBB2H&clientid=bmaparts&clientid=bmaparts
if you call, they have another brand, zimmer or something with a z, i forget what...its $45
*edit* oh...and check the one on the front of the engine too...just follow the wire from the cam cover area down to the crankshaft...make sure its not cracked/cut etc, mine was...
i checked out the site and the bmw brand was 86.00 a bit lower than Bav, I'll call tomorrow to check on the cheaper one. Thanks!
1 - 4 of 4 Posts
