Hi!
2000 528i M52TU, 220'000+ miles (or maybe more, my cluster is broken and odometer is showing 999999 which is another topic and i don't know the fix
I'm trying to tackle the VANOS repair, I ordered the kit with anit-rattle rings. So I want to get the rings and the washers done inside the piston, along with the seals (o-rings) on the outside.
I have no issue with taking off/replacing the o-rings, but man I CAN'T GET THE DARN PISTON OPEN!
I tried all different kinds of vice and even a breaker bar on the 24mm socket - the bottom part just keeps slipping at the bottom, I can't get the cap open no matter how I try!
The Beisian guide implies it's as easy as having a vice and impact wrench
http://www.beisansystems.com/procedures/double_vanos_rattle_procedure.htm
and 50sKid and his youtube video "BMW 330i 325i E46 Vanos Rebuild" @at 17:40 https://www.youtube.com/watch?v=0eUVF6OLFFg it seems very easy and straightforward.
I tell you I tried all sort of things and all kinds of vice. I don't have an impact gun... and I don't have a wooden vice, honestly. But wouldn't a conventional iron vice, and a breaker bar to a better job (which I tried, and it's not help)??
Any of you who've done that, and have experience with that, how easy was it to crack the piston open? Any tips or tricks on how to do it easily? May be spray something on the threads around the cap, because after 200 kmi i believe it's pretty cooked?
Btw, i tried the piston on the shaft, there isn't much "axial play", and I honestly haven't been noticing any of the "rattle" in the vanos area. So, what would you say, I *do* want to get the anti-rattle rings done because I know I never gonna get there ever again.. but on the other hand I don't want warp the pistons on the outside with the jaws etc by applying too much force. Should I just skip doing the anti-rattle rings inside, and just do the o-rings on the outside and be done with it??
Any suggestions? please. I'd like to hear your story.
