Go to Autozone and rent a Fuel Pressure Gauge for Free!
Other Automotive stores will do this also, if you are not near an Autozone.
I say this because I, too, ASSUMED that I was getting fuel because when I pulled the plugs on a NO Start condition,
the plugs were wet and distinctly smelled of gasoline.
My assumed diagnostic sent me in a time wasting direction.
When I did a Fuel Pressure test: I had Zero fuel pressure......Yes, Zero pressure but my plugs were wet with gas ...
For a preliminary test:
Turn the key to the on position for 10 seconds.
The Fuel pump will activate and should pressurize the fuel rail.
Depress the center pin in the Schrader valve on the fuel rail.
There should be a squirt of fuel.
That is not a definitive test, but may tell you if the fuel pump is bad if you have Zero pressure.
If Zero, Check the fuel pump for voltage.
There will be voltage for (only) the first 4 seconds after the key is in the ON position: so watch the voltage meter at that time.
If the car is started, there will be voltage all the time the engine is running, of course.
