1 - 2 of 2 Posts
Hello fellow BMW Owners, can anyone kindly let me rent their N54/N52 Front Crank Seal remover tool for ONE day?? I litterally spent 5 hours trying to pull out the stubborn seal with hooks, picks and even a torch lol..
Is there any concern of damaging the actual crank and maybe walls (I was very careful..)
I am located in Elk Grove (basically Sacramento, CA) and I can pay for shipping to and from, and how much ever you want to charge for me to rent it :angel:
Thanks in advance guys !!
BMW tech here,,,,you drill two small holes in the seal,,,,then you find two screws and screw them into the holes you drilled,,,,then take some pliers and pull on the screws and the seal should pull out,,,,check out my blog there might be some pictures bmwtechnician. com
1 - 2 of 2 Posts
