2004 M54 330i petrol auto
Greetings all from a newbie, just looking for some more check points to a non starting engine. Symptoms have gradually got worse over several weeks and now failing to start with continous cranking. I've listed checks and parts replaced so far as follows:
Difficult starting engine from cold with symptoms of very poor idle (100 to 300 rpm) and stalling. Once started after 3 to 5 attempts, engine runs very lumpy and pumping the accellerator pedal has no affect or any increase to the rpm. After around 30 secs of lumpy idle, the engine becomes smoother and idle rpm becomes normal. Vehicle drives moderately fine after warming up but still has some irratic idle with hesitant acceleration. Occasional misfires with CEL and fuel cutoff on cylinder 3 and 5 which clear after a code reset with basic OBD tool.
Visual inspections completed:
no smoke, no overheating, no coolant/oil/fuel loss and no coolant/oil mixing.
No codes or sensor codes apart from occasional misfire code on cylinder 3 and 5.
Check points and parts replaced:
Swapping coils and Replacing all 6 with new.
Cleaning spark plugs and Replacing all 6 with new.
Start with MAF disconnected/connected and New MAF.
Vacuum leak test with compressed air.
Replace Radiator lower Coolant Temp Sensor.
Previous major work carried out after a burst exapnsion tank (stuck closed thermostat)
and several months before the above symptoms:
New coolant hoses, expansion tank and coolant cap.
New water pump, thermostat and viscous fan.
I dont have access to any compression/pressure testers but looking at possible
fuel pump or injectors but also possible valve/cylinder compression issue.
Not wanting to spend more on replacement parts if also possible head gasket or
crack in cyclinder or stuck valve causing poor compression.
Any advice or additional pointers greatly appreciateda dn thanks for reading.
