1 - 2 of 2 Posts
The creaking windows are quite likely caused by your door seals. Get some gummipflege from the dealer (vaseline type product) or other rubber care gel and apply to your door seals. Might be an idea to clean the door seals first with some warm water and mild detergent first.
The door seals are a combination felt / rubber item, apply to the the rubber part. The creaking window sounds occur when moisture or dust gets in between the body and door seal.
Since you live in the land lots of rain (and taxes), that is what your problem is likely to be.
1 - 2 of 2 Posts
