Hey all,
I've done a search of the following part in the forum but have found nothing come up. I apologise if anyone has answered this question in the past.
My Z3 has a Cylinder air intake warming controller (11611247752) that seems to be corroded in the pipeline. The car hasn't been running on the road for the past year or so; however, when it was, it ran alright but had no real power. It is hardly surprising tho because it is the 1.9L 1997 automatic. When I run the engine now, it all sounds good.
Does anyone know if this can be cleaned out (probably with a drill) or does it need replacing? The corrosion deposits are extremely hard in there but a drill bit turned by hand has started to remove it. I'm just not sure on what is goin on inside - if there are any channels that may be blocked other than the pipes.
Also, if anyone knows of any other items that may be affected by this.
Thank you
Thank you
