1 - 4 of 4 Posts
car: 2003 BMW 540i E39 94Kmi -new battery in last 3 mos.
Problem: lower dash display is blank - no oil usage, OBC display, no odometer, trip, etc .
buttons on display don't work. Gas gauge at zero, no tach reading. Pixels were good when last readable.
background info: car wouldn't start or cranked very slowly after about 3ea 10 mile trips in cold weather. solution: found loose battery neg lead, tightened. Car now starts but now have dash display issue. Dash display was replaced in the past before I owned the car, and I assume was coded to the car. If I disconnect the battery for the 10 minutes to get it to reset, will I have to take it to the dealer to have it re-coded? I had to do this for the MID radio display when it went blank - shut off after 5 minutes.
Is there a solution for re-coding used part into the OBC, other than the dealer?
10 minutes is not enough, open your boot, wait 16 minutes for the car to go to sleep, then disconnect the battery.
No re-coding is necessary. Newer cars may need this, not the e39. Throw in a new battery, put terminals on, drive, thats it.
have you got a code reader?
You can code your new parts yourself, just search...
Discussion Starter #3
Dash Display problem - solved
I removed the battery + cable for about 5 min. and reinstalled the cable. Everything is now back to normal. I was not sure about losing the coding for previously replaced items.
Reply to 528iAut: I have a Bosch OBDII reader, but I do not recall anything about being able to re-code new/different parts that are being replaced in its menu. What reader tool are you using? I have read on the forum about CARLY and INPA but still researching what additional tool to get for in depth monitoring and re-coding.
Don B
1 - 4 of 4 Posts
