I have a 1993 318I. My fuel, tach, temp and spedo are dead. The other dash Lights seem to work, turn indicator ect. I have a display of " code " in the odometer . pulled the codes and got a 1444. tested the fuses ok tested the power lead to the cluster had power at the intrument anel plug as well as the ground lead was good. when the instuments died all the dash lights came on as in the start up mode. this happened a few time before it quit altogether.
Any ideas where the problem is.
