1 - 3 of 3 Posts
Hello
in my Z4 the yellow motor warning light is burning. OBD2 tells me that the diagnosis lambda-sensor cyl. 4-6 has no connection. I found a broken plastic sleeve on the connector.
At the local dealer ( I live in Germany) the friendly expert told me that the cable harness has to be replaced as this connector is not available as a spare part.
I don't like this as I fear that half of my car has to be detached and the bill will be exorbitant.
Has soneone an idea?
I have been told by a german guy to cut the connector completely off and solder the wires. Is this a good idea?
Thanks in advance
PeterSTW
from Waren, Germany
If you can cut the connector out and solder the wires, why not replace with any type of connector that will work....
My 2 cents worth....
Either way, soldering the wires or buying a generic connector set is a better alternative than the whole engine compartment wiring harness.
Mouser Europe carries Molex automotive connectors. They're inexpensive and reliable.
https://eu.mouser.com/Molex/Connectors/Automotive-Connectors/_/N-1ehb5?P=1z0zlewZ1z0spqaZ1yvsm2a
1 - 3 of 3 Posts
