Hey all,
I'd like to start off by saying I am new to the forums because I'm new to BMW. I love my car and it had very few issues at the time of purchase. This one was caused by a dumb decision by myself capped off by a detailer who messed up (going to be talking to him next week in person)
Everything had been FINE mechanically and cockpit-wise as far as lights go. After I got the engine bay washed, I started the car, seemed fine...shortly after, I got the ASC and ABS lights and my tranny (auto) started to behave oddly and eventually went into "limp" mode with the EML and tranny lights intermittently coming off and on coupled with the oil temp gauge shooting up to the max (which seems to have inspired the former). Pulled over, popped the hood, figured it might need some time to dry out. The engine seemed very...shiny. Almost like there was tire shine or some sort of cleaner that wasn't fully cleaned off still left on it. Or it could have just been a side-effect of whatever he used.
Dried some areas by wiping, got back in, same issues persisted as above.
Pulled over again, jumped online and searched. Quickly came across multiple threads that are available here (have read through many of them extensively, I promise), which somewhat saved me because I figured out I could simply unplug the module and drive that way until I figure it out (THANK YOU!) -- water came dripping out of the connector when I did this. The water was a browny colour - could simply be dirt mixed in, but there was definitely water inside the connector.
After I let the connector "dry out" with it disconnected for a couple days, I reconnected it (today) and there was absolutely NO noticeable difference than when I had it unplugged immediately before. Drove 300 km and still, no change.
Saw my indy today, OBD II scan came up with communication errors for a few different things, but among them were transmission and anti-slip system. Cleared codes, engine light went away, drove for a few mins, came back (ASC and ABS lights have never cleared at all). Scanned again, same result.
Taking it a step further, my indy's scanner was not at all able to communicate with the ASC/ABS module - simply nothing.
--- PURCHASED CONFIRMED-TO-BE-FUNCTIONAL ABS MODULE FROM A REPUTABLE SHOP RECOMMENDED BY MY LONG-TIME INDY MECHANIC AND REPLACED IT ---
I am WELL AWARE that coding is needed for replaced modules - but I am also well aware that, electronically speaking, something should be communicating with a working module, whether or not it has been coded (this just seems logical but PLEASE advise if I'm off base). The results were EXACTLY THE SAME - it is as if there is no module connected at all. Took it a step further and used an actual BMW reader that his neighbour has (forgot model and software details, will ask mechanic next week). Read everything, and showed a few different ECUs without any communication - vertical headlight adjuster (lol), a few others, and the ASC ECU was among them as before!
This is leading me to believe that there could be a deeper electrical issue. I'm going to try to test my module in a different car (might be tough) but was hoping to get some insight here before diving in. I had gotten to the shop late and we had no time to go further than this. The replacement module (that I'm not even sure I should have purchased now) is connected as we speak but seems to be doing nothing whatsoever.
NOTE: detailer did my exterior and went hard on my rims, SPECIFICALLY THE FRONT-RIGHT RIM. Granted, my issue seems like it isn't wheel sensor-related, but that is worth mentioning. I'll try to do some DMM tests this weekend on the connector at least. I have a bad feeling that the harness got fried.
QUICK FINAL NOTES:
-I drive a 2001 530i automatic
-From searching, I believe I have a Bosch 5.7 unit, part number ends in -001. The unit I got when I bought the car was already rebuilt by BBA as per the orange warranty sticker I see on it
-Since my problem's inception, the ASC and ABS lights have been ON all the time, no matter what, immediately upon starting the car
-Unplugged/reconnected battery - clock reset but nothing else (we know this, just saying)
-Clearing any codes using any scanner of any type, has never ever affected the ASC or ABS lights - see third point
-I have had no issues at ALL with brake-related dash lights
-My speedometer, odometer, trip meter, fuel consumption and cruise control all DO NOT work
-Gas gauge is not reliable, though it seems to find a happy place sometimes
-Gas consumption has increased (efficiency has decreased)
-Shifts are not as smooth and seamless as before, though not to the point of being at all "concerning"
-Tranny in sport mode is noticeably not as nice
-Since the wash, I've noticed my idle has become a bit odd - cold start it is slightly shaky (this was happening before but got a bit worse) and after slightly hard braking or constant braking in traffic the RPMs will dip right down to that one white line and vibrate a bit, then come back up to its expected spot.
THANK YOU FOR READING!
QUICK FINAL NOTES:
