1 - 8 of 8 Posts
Hi all,
I want to change the oil in the diff any idea what type i use and how much i need my BM is 91 525i M50, its got a slight leak so im not sure how much is in there
many thanks:thumbup:
Discussion Starter · #3 ·
oil
Hi Info,
not sure about LSD,how would you now i have noticed that when i try to wheel spine it doesnt really happen,you get a slight spine for a split second but nothing much but the acceleration is very good so im thinking it has LSD is that a good guide as for the leak im not really sure if i can fix
many thanks
laney
No more e34!
LSD starts with S on the diff tag.
I have an LSD, and am running mobil 1 80 (or 85)-140, as that is the equivalent of the CURRENT BMW suggested fluid.
the used to use 75-90, but just try pricing the BMW stuff... I dont think you can even get the old stuff for less than $20 a bottle
Bentley has the specs but youll need two quart bottles and have some left over.
Make sure you can open the fill plug before you drain it... ok?
Discussion Starter · #6 ·
Hi info
do i need a mighty vac or can it be done by hand failing that i might be better off taking it to a mehcanic
many thanks :dunno:
And be prepared for the smell of spent gear oil. Bleech!
1 - 8 of 8 Posts
