1 - 9 of 9 Posts
· Registered
I have a 2001 E46 330i SP/5sp. and I'm looking into the Dinan CAI and Software upgrade. I'm curious to hear feedback from anybody who already made the purchase.
I installed the BB TriFLo w/Twin 3" Round Tips last year and if somebody has that combination or any aftermarket exhaust I would love to hear your thoughts
· Registered
Discussion Starter · #4 ·
the software upgrade is a biproduct of the CAI. I am told without the software the engine will run to lean; triggering the check engine light. Have you heard the same?
I was also under the impression that attempts to make more HP have been unsuccessful with all aftermarket manuf. (?)
· Now with Nano
false. the engine will not run lean because the ECU will compensate for it based on the amount of air passing through the MAS as well as the signal coming from the O2 sensor (which measures the difference in oxygen content between the exhaust gasses and the outside air).
actually, there is some truth to the story in that when a CAI is installed (only) Dinan stage-I software and the OEM software will trigger a fault code. even then it's a rare occurance that will happen under extreme conditions. I heard from a VERY reliable source, that the diffrence in the software involves fixing a *factory* miscalibration of the catalyst overheat protection system that is only triggered with a CAI. only Dinan does this (forces you to upgrade - albeit at no charge- when you buy a CAI). all other vendors of BMW software to my knowledge compensate for this in their one and only version of the software. I suppose Dinan has their reasons for doing this along with their reasons to not muck with the VANOS via software for non-supercharged cars (per their software engineer).
false. the tuners that *are* making HP (at least three that I know of - more like everyone BUT Dinan) are fooling around with the VANOS (changing the cam timing electronically via software).
I have personally answered these two questions numerous times on several bulletin boards. :banghead: a search of the archives might yield even more info.
· Now with Nano
TD330ci said:
When Damit WHEN!! :mad:
I thought it was suppose to be out by now!!
Any clues?
from what I heard a few months ago, it's due out between about now and 30 days from now.
as you may know, the plug is different on the newer cars and a new injector had oto be developed. search the archives.
· Registered
Discussion Starter · #8 ·
31st330i.........Thanks for the informative and visually appealing answers. As you can tell from the large digit # next to my name....I'm fairly new to this board.
I promise to search the archives for more of your "informative and visually appealing answers" if you promise to stop this guy from smacking his head against the wall.:banghead:
ps. Thanks again for the info:)
Tanin
1 - 9 of 9 Posts
