Hi Everyone. I have a bit of a unique problem. I recently had a EWS delete done on my son’s 99 328i. His car had random non starting issues that we finally traced to the EWS, so we did the delete and it worked well. During the diagnosis stage we had also bypassed the ignition, so the car starts with a button which is wired to the starter. So, the good news is the car starts and runs great. The bad news is that shortly after the delete, his key died and he put in a new battery and tried to program it to the car but it doesn’t seem to work. His key is the slightly older version. The three button with the rounded back edge. Not the diamond shape.
So, now every time, and I mean EVERY time he opens his door the alarm goes off. I pulled the fuse for the sound, but the lights flash for several minutes. Since the delete and bypass have been done, the car will still start and run during the time the alarm is going off, but at night it is rather distracting to say the least to drive down the road with lights all flashing.
Also, none of the door locks function from the key remote or from the lock button in the car. You have to lock and unlock the car using the key manually in the door lock.
My question is does anyone know how to prevent the alarm from going off? Maybe even using a programming tool? We’ve tried everything to try and get this car to run without issues, and when it runs it does great. But it always is one issue from being really good. And this issue I haven’t been able to solve.
Thanks for your thoughts.
