1 - 13 of 13 Posts
Keeping it surreal
Those look quite tasty.... if you`d care to send me a pair, I`d gladly mount them and give you my totally unbiased opinion of them.... :)
Regards,
Bob
(Actually, carbon steel is great for knife blades, axes, etc., but a rotor`s only job is to dissipate heat quickly....cast iron is unbeatable in that category, unless you want to drop around 8 grand on a full carbon-fibre setup....)
Discussion Starter · #4 · (Edited)
Thanks for the reply .Do you believe these discs would perform as well as oem?Iasked about rusting and$80 dollar option for nickel plating all 4 rotors blinggg......
Keeping it surreal
Do you have any information on these rotors ?Ignoring the cost how do you feel about the design and material choices will they warp etc ?
IMHO, these are no better or worse than any others (although their heat-dissipation ability may not stand up to cast iron`s). Rotor warpage is almost non-existant on street-driven cars....It`s your money....
Regards,
Bob
Ubergeek
Sorry, I can't ignore the cost. Cheap zimmerman rotors work great for me autocrossing and on the track.
For Street use they might be OK, I would not use them for HPDE's. The drilled holes might look cool but, they will not handle repeated abuse at the track without cracking.
Discussion Starter · #11 ·
Thanks for input do you think they will crack because of the material or do you not trust drilled rotors ?
Black Mage
Regards,
Bob
Correct me if I'm wrong, but doesn't aluminum dissipate heat almost instantaneously? Or maybe that only applies to aluminum foil. :dunno:
Steel dissapates heat best.
Aluminum next.
Then iron.
Iron resist heating to but holds heat longer.
1 - 13 of 13 Posts
