1 - 3 of 3 Posts
Can you please tell me how to disconnect the battery in my 2004 330cic? I am having a heck of a time getting the positive cable off, but the negative loosened just fine. But is now sparking?
Keeping it surreal
Don`t be intimidated by that big red cable....just remove the clamp`s retaining nut, and using a thin-blade screwdriver in the clamp`s slot, pry the clamp open while wiggling the red cable back & forth, lifting up on it at the same time. Just be careful not to ground the screwdriver against any other metal while you`re doing this. If all else fails, auto parts stores carry special pullers specifically for this.
Regards,
Bob
Discussion Starter · #3 ·
Regards,
Bob
Thanks, I finally was able to remove it.
1 - 3 of 3 Posts
